Posts: 42 Prescott, AZ | Where does the black wire go? The instructions say to connect to a "good ground source". Does that mean the black wire connected to the existing plate light bulb or do I need to find a piece of metal to screw it on to? Thanks. |
Posts: 233 flagstaff, AZ | black wire should be fine,. |
Posts: 74 Navarre, FL | I tapped mine into the existing wires using the posi-taps. Works great. |
Posts: 42 Prescott, AZ | Thanks. |
| PM me you address and I will send you some posi-taps. Will send you copy of that page/s of service manual if that helps. |
Posts: 366 Albuquerque, NM | Did you have to remove the trunk and painted v-panel to access the light wires? |
| When I do the installs here...I remove trunk and M panel to access wires. Drill small hole in existing lens or M panel to feed LED frame wires thru. |
