| I'm market fishing so i needz to know what kind of aftermarket parts you guys want to see for you Vision and X bikes. I'm talking steel, aluminum, Rubber, plastic. Anything. Even if someones else makes it and you think it should be better I want to hear about it. Be discriptve if nessesary LG |
Posts: 965 New York State | The passenger backrest luggage rack Ma Vic discontinued would be a nice option.
Do not know if this could be done but Handel bars that are adjustable would be cool.
The ability to push the hand position forward when two up and closer when solo
Edited by Trekwolf164 2012-02-23 3:46 PM
Posts: 2300 Georgia, west of Atlanta | Stroker cranks: 4 3/8" and 4 1/2" options..... : )
Edited by XRsteve 2012-02-23 4:23 PM
Posts: 1229 Rancho Cucamonga, CA | Ram Air intake.
2 into 1 exhaust, making the dummy muffler into an aux fuel tank.
Edited by Nozzledog 2012-02-23 4:40 PM
| Quick detach rear passenger backrest that slips into a slot in the seat or mounts under the seat so you don't have to cut a slot in the panel behind the seat.for the occasional passenger. |
Posts: 520 Simi Valley, CA | Retractable wheels
Warp Drive
Tractor Beam
Phaser Cannon |
Posts: 1229 Rancho Cucamonga, CA | HUD
R.A.T.S.
(rocket assisted takeoff system)
Posts: 155 Stockton, California | LED driving lights like the Clearwaters that have a control wheel that will fit in the 4th slot on the console on the Vision instead of the separate knob mounted on the bars or body.
Another option for lowers on the Vision (that come with mounting brackets)
exhaust tip options
HIghway pegs/boards options
Posts: 31 Boise, ID | Passenger backrest for the Vision would be great. |
Posts: 215 orrick, mo | A dash for the VV that doesn't rattle! |
Posts: 523 seattle, wa | Lights, in place of reflectors like they have on GWs.
A filler for the removal of passenger hand rails, in place put a chrome rail tucked up tight to the rear of the seat.
Passenger backrest luggage rack.
Dashboard storage.
A radio antenna that mounts on the rear of the bike. |
Posts: 185 Rhode Island | The thing I would buy for the Vision is a dash bag/organizer; want a place for glasses, phone, and speed pass anything else is a bonus.
The next thing would be a kickstand extension to make it easier to hook my boot on.
Jim
Edited by RhodeTrip 2012-02-23 7:28 PM
Posts: 804 Perry Hall, MD | Thanks for asking.
For Vision:
A hinge and hidden lock system for the panel behind the seat permitting use of the cavity for hidden storage.
Quick detach mechanism for the trunk, with no requirement to remove license plate.
Solo seat with extended street model body panel.
Gauges built into the instrument cluster for oil temp and tire pressure
+1 on the adjustable handlebars
On-board air supply for rear shock with 2 memory preset switches for solo and two up riding.
Leather cover for front access panel
Heated grip options - for appearance and feel - added padding and diameter.
An effective antenna.
Posts: 1229 Rancho Cucamonga, CA | lennyb - 2012-02-23 5:48 PM
Thanks for asking.
For Vision:
lennyb, you are right on the money, all do-able and wanted! Love the air supply idea, could even intergrate a chuck for filling the tires in an emergency (onboard compressor). |
| RT, Noemtz.com has a kichstand extender! 20.00 I love mine!! |
Posts: 8144 New Bohemia, VA | Solo Seat for the Vision, with compartment. |
Posts: 104 ROCHESTER,NY | Everthing Trekwolf said!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Posts: 849 , FL United States | Blister - 2012-02-23 9:57 PM
+1 been using mine for 3 years and love it! |
Posts: 135 Chesterfield, VA | How about some sort of slide out highway pegs for the passenger floorboards on the Vision. I almost feel guilty about all the leg adjustments I can make while my wife is locked into one position with no way to comfortably stretch out her legs. |
Posts: 249 Phenix City AL. | I have a passenger highway peg mount, pm me |
Keep them rolling guys, Within Reason that is,
Posts: 965 New York State | Fork mounted machine guns with helmet mounted active sight http://theuprightmotorcyclebrigade.files.wordpress.com/2008/08/orig...
Edited by Trekwolf164 2012-02-24 7:02 AM
Posts: 284 mansfield, MA United States | Sounds like the new R&D at Llodz is up and in full swing. OK you asked so here is my wish list.
1. A turbo kit.
2. A power center stand that doesn?t scrape
3. A easy on easy off passenger cup holder
4. A better option for the cheese wedge (I would love to see one with infinity light like this http://www.reflectionproducts.com/Infinity.htm)
5. Ok I know everyone is looking for this so I am throwing it out there. A body kit to make the bags bigger.
| lennyb - 2012-02-23 8:48 PM Thanks for asking. For Vision: +1 A hinge and hidden lock system for the panel behind the seat permitting use of the cavity for hidden storage. incorporate with trunk removal +1 Quick detach mechanism for the trunk, with no requirement to remove license plate. Its not getting the trunk off, It's snapping the pannel in & out +1 Solo seat with extended street model body panel. +10 Gauges built into the instrument cluster for oil temp and tire pressure Remote oil temp on Dash +1 Leather cover for front access panel I had mine Clear coated. +1 Grip options - for appearance and feel - added padding and diameter. Grip Puppies www.CasportTouring.com (SKU-GPGL) |
Posts: 131 Edmond, OK 2012 Vision, 2012 Cross Country | As far as the Vision goes, make the CB oem instead of having to purchase it, Dash storage, lit switches, move the radio where the switches are and put it at an angle and the switches in place of the radio, optional lower seat height like the 8 ball has. The CC, red turn signals for the rear of the bike, have them all like the CCT with the lowers being the same. I do have and ride both bikes. Thanks for asking us all for our input Lloyd. |
Posts: 935 Rockford, IL | Wow....quite a few dreamy requests so far I'm keeping more realistic with some of the following....all Vision related....
A basic luggage rack for less than $150. Don't need chrome or stainless or powder coated or anything fancy. Just a nice chunk of metal with mounts and the purchaser can finish however they wish. If they want to spray bomb in their garage or if they want to take to a local powder coater or chromer or whatever, its up to them.
How about something for the bottom of the forks? Like spikes or rounded caps or similar. Again....keep it basic and allow the purchaser to finish how they wish. Same thing for the handlebar ends.
Metal front fender with a functional mud guard as an option? Heck, just a functional mud guard would be nice.
Some type of cover for the battery or oil cooler? To dress up/hide
A Lloydz license plate frame !
A curved laydown lighted license plate frame. And guess what....keep it basic again.
Mounts for fork mounted driving lights. Just the mounts....no lights. Allows us to use almost whatever brand driving lamps we want.
Ram ball mount that actually properly fits the Vision handlebars. And one for the passenger grab bars.
GPS mount that clips or clamps to the lip of the top of the dash.
While I don't think I need/want....but....perhaps a fork brace? Skip turbo....I want a SUPERCHARGER....I know....I got dreamy....sorry
Posts: 215 orrick, mo | +1 on the metal front fender--make it a full one piece though
Edited by buzz64077 2012-02-24 2:11 PM
Posts: 262 Flowery Branch Ga | +1 on the full metal fender and light mounts. Cheap exhaust (allowing for more sound volume, not straight pipe loud) upgrade that looks factory,can be used with other upgrades, but doesn't need any upgrades to be used alone. |
| How about some sort of NEW INNOVATIVE but PRACTICAL Cup Holder. This has been the hardest bike to find a GOOD, Space saving, CHROME, stable CUP HOLDER. I have tried the Willie holders, the Kruzer Holders, the Magnificent holders, and about 10 more other kinds of holders.
And don't ask exactly what I'm talking about for the XCT's...but I'll know it when I see it (and buy it). :-)
Wally |
Posts: 307 Columbia, SC | +1 on functional luggage rack that is half the price of those chrome ones
And not sure if I need it, but functional cupholder mounts for grab rails and the funky vision bars would make a lot of sense. |
| sfalexi - 2012-02-24 8:20 PM +1 on functional luggage rack that is half the price of those chrome ones And not sure if I need it, but functional cupholder mounts for grab rails and the funky vision bars would make a lot of sense. I would have to agree with this, 500.00 for a chrome luggage rack is a bit extreme even by Harley standards. |
Central Wisconsin | Lloyd - 2012-02-24 6:35 AM Keep them rolling guys, Within Reason that is, Nice to see your open for suggestions. +1 on a Lloydz fork brace, possibly doubling as a bracket for driving lights.
Posts: 669 Peachtree City, GA | varyder - 2012-02-23 10:26 PM
+1 |
| Thomas - 2012-02-25 6:10 AM Lloyd - 2012-02-24 6:35 AM Keep them rolling guys, Within Reason that is, Nice to see your open for suggestions. +1 on a Lloydz fork brace, possibly doubling as a bracket for driving lights.
I have a fork brace on my HD. First thing I added. |
Posts: 2300 Georgia, west of Atlanta | Special application cases for bore sizes up to 4.5 inches...... |
Posts: 742 North Orange County CA | A back pad for the tour pack that incorporates a lumbar support, and an upper pad that is inflatable to change the degree of recline in the passenger seating position.
Maybe it could utilize some air cells and a bulb pump, or steal a little air from lennyb's and nozzledog's on-board compressor ?
A hard plastic liner for the cavity under the trunk that bolts in place and incorporates a locking lid.
Posts: 8144 New Bohemia, VA | Webhair - 2012-02-25 7:38 AM varyder - 2012-02-23 10:26 PM Solo Seat for the Vision, with compartment. +1 ...guaranteed to be the million-dollar baby...especially if it is plug and play, and as easy as swapping out the trunk and seat... |
Posts: 3204 Memphis | varyder - 2012-02-23 9:26 PM Solo Seat for the Vision, with compartment. and optional backrest. |
Posts: 329 scotts valley, California | I am wanting a solo seat for my VV also. The other day I left the stock seat at a shop for a day or so and rode with just a chunk of 3" foam right on the frame. Talk about low! A nice low solo saddle with about a 10" high back, like some of the old Spanish horse saddles would be sweet. Yes, I still want the pick-up bed behind it too. |
Posts: 423 northwest florida | what about a mounting bracket to attach lights just below the headlights.
Posts: 249 Phenix City AL. | The trunk filler panels modified with a hinge on the bottom and latch at the top, or hood pins, so that the pannel opens, like an old rummble seat, that would allow a bag to fit in. Call it the rummble rack. |
Posts: 2300 Georgia, west of Atlanta | Turbocharger or supercharger kits capable of 175- 200 HP............. |
Posts: 3773 Pittsburgh, PA | maybe some sort of Vision Fork tube covers? Our forks are pretty lame looking in grey.. |
Posts: 258 Akron, Ohio | I like a quick disconnect system for the trunk on a Vision. I have the filler panel and have only used it once |
| A flag mount that excepts flags bought from American Legion and it mounts on the front of the bike. Maybe one I could drill a small hole into the lower part of the windshield? Or anywhere besides the luggage rack so when I remove my trunk it's still flying high.
A few years back Kuryakyn made pass. floorboards for the GW that had a "L" piece that would flip up using the foot this gave passengers a second position for the feet and legs.
A good size cup holder that either fits the square bars or mounts to the controls some how. So many cup holders only handle cans but when I ride I like the squirt bottle that some drinks come in. The bottles are a little bigger around but it so much easier to pull the lid with my teeth to drink. |
Posts: 117 Kansas City, MO | Would love to see a cig lighter that dosent look like crap |
| lennyb - 2012-02-23 7:48 PM
Thanks for asking.
For Vision:
+1 |
| Modified saddlebags, that eliminate the pistons, maximize the size, and retain your existing saddlebag body panels.
Air pump/release for factory shocks that uses aux switch on dashboard, and dash mounted micro gauge.
Garage door opener that uses high/low beam switch.
Secondary air intakes that replace cheese wedges.
Secondary ram air intakes that replace aluminum dash valance on front fairing. - This could also be adjustable air that can blow on the rider.
Secondary ram air intake that replace existing front blinkers, but retain the blinker by making them smaller LEDs. - This could also be adjustable air that can blow on the rider.
Front blinkers with removable lens, and an assortment of custom lens/covers. Matching rear lens options.
Weight reduction accessories.
Xbike trunk mount kit.
modified clutch piston for easy pull.
Multi setting ECM with weather proof dash mount that allows for quick preprogrammed settings for high performance, loaded pulling power, fuel economy, and factory standard.
Pullback bars.
Better tie down points
Expandable dash mounted micro gauge cluster for engine temperature, shock pressure, and oil pressure. It would be even nicer if is an integrated module that plugs into the existing LCD display, or a download to the computer that shows this information on our scrolling screen.
Heated backrest (driver and passenger), heated passenger armrests.
Edited by sgiacci 2012-02-29 3:18 PM
Posts: 2300 Georgia, west of Atlanta | Digital dash gauges similar to Dakota Digital............... |
Posts: 16 Sydney - AUSTRALIA | For the XC/XCT the following:
Inner liners (not bags but felt type liners similar to HD) for the trunk, saddle bags & lowers storage area;
Relocation of the ignition to the dash area (same as Vison);
Proper break peddle;
A way to change the clock from 24 hr mode to 12 hr mode when the display is set to metric;
Relocate rear air shocks valve to an area where you don't have to take the side panel off (again similar to HD);
+1 on cheaper trunk rack.
Posts: 42 Prescott, AZ | sgiacci - 2012-02-29 2:17 PM
I thought everyone hated the look of the Xbike trunk mount kit. I know it I do. I would like a quick release, but don't it as ugly as the XBike's.
I think heated backrests are a great idea. |
Posts: 16 Sydney - AUSTRALIA | Oh one more thing that I can think of is a Centre Stand similar to the third party stand by Ezy Up for the HD. It's a great stand and I only wish they'd make one for the XCT. From all accounts the Victory and other third party centre stands aren't up to scratch.
Posts: 1632 Jasper, MO | Easy-Up center stand, as long as it doesn't lose any cornering clearance. I don't care if you can operate it while sitting on the bike or not, as long as it gets the rear tire off the ground. Given the long suspension travel of the Vision/Cross bikes, a two-stage stand like the ones on the old Kawasaki Voyager XII might be a solution.
On board rear suspension air pressure pump and adjustment. Maybe double as an air supply for tire inflation, but not a requirement. On-the-go rear suspension adjustment and pressure readings would be nice.
Ronnie |
Posts: 965 New York State | The Police variation of the Ness Bash plate |
| A luggage rack for a Vision Tour that does not cost me a kidney to get. I bought a HD trunk rack for my 07 Kingpin Tour at the HD dealer for $140 that worked perfectly. Rounded chrome bars that were about 1/4 to 1/2 inch thick with plenty of cross members and tie down spots. Doesnt need to be super elegant...just work and enable me to carry my wifes crap on a long weekend. Why does everyone think trunk racks should be $400 for these bikes? Please help! Thanks |
| Wanted to add...
1)Brackets for lights under the driving light of the Vision
2)Adustable rear pegs for passenger to move around on long rides.
3)Did I mention an affordable trunk rack?
4)Prepainted gauge bezel for Vison to replace stock "black" bezel. Both pieces...around speakers and chrome piece around gauges.
5)Flag mount for proposed trunk luggage rack.
6)Handle bar mount for extra cig lighter so I can charge my phone without opening glove box.
7)Quick disconnect for trunk.
8)Cup holder that goes on opposite side of handle bars...not right in front of me.
Thanks again.
Edited by kpVision 2012-03-15 3:45 PM
| Reverse that will work on all model year Visions and Xbikes. |
| OK...here's what I would REALLY like to see some vendor tackle.
Heat Deflectors that fit on the tank and along the side covers LIKE THE NEW 2013 Harley's have put on all their touring bikes. THIS IS NEEDED BADLY!
A small shield that latches into the holes on the speaker that puts an "awning" over the speaker. Something that could be put on and off easily. Kind of like you see on car windows to allow for the window to be rolled down while it's raining...this would work on the same principle. |
Posts: 537 , FL United States | One goodie I would like is to have someone like Llyod or Kevin a little closer that can do some work on my bike instead of a 5 hour trip one way. Then maybe I could get the cams, bigbore kit, some tuning or hell being that close I might opt for a nitrous bottle. |
Posts: 231 Desert Hot Springs (Palm Springs area), CA | kpVision - 2012-03-15 3:44 PM Wanted to add... 1)Brackets for lights under the driving light of the Vision 2)Adustable rear pegs for passenger to move around on long rides. 3)Did I mention an affordable trunk rack? 4)Prepainted gauge bezel for Vison to replace stock "black" bezel. Both pieces...around speakers and chrome piece around gauges. 5)Flag mount for proposed trunk luggage rack. 6)Handle bar mount for extra cig lighter so I can charge my phone without opening glove box. 7)Quick disconnect for trunk. 8)Cup holder that goes on opposite side of handle bars...not right in front of me. Thanks again. I've a solution for #8)Cup holder that goes on the opposite side of handle bars. I put a Kruzer Kaddy (in black) on my left handlebar, just next to the clutch. Here is a picture. It works great!
Posts: 1229 Rancho Cucamonga, CA | ArkieBiker - 2012-03-18 9:46 AM
Something like this?...
 (2011-04-01 14.28.27a.jpg)
2011-04-01 14.28.27a.jpg (89KB - 19 downloads)
| OK Nozzledog FESS UP. Where'd you get such a rare item like that? INQUIRING MINDS want to know. :-) |
| Vision models
chrome shifter rod with ends
chrome bolts for front rotors
nicer oil dipstick
02 sensor covers ones that will slip over with out having to take them out to install the covers
chrome cover for the gear indecator behind the rear cylinder
chrome master clinder cover for the body and and clutch
Posts: 215 W'ford Tx | +1billion for a body kit to make the side bags bigger. |
Posts: 249 Phenix City AL. | passenger high way peg mounts, I make a set if you are interested
passenger cup holders, their is a thread on how to install a ram mount to the speaker covers, to allow a ram mount cup holder I could make a kit to include 1 ram mount, 4 mounting bolts, 1 backing plate, and a template to drill the holes.
lite mounts, how about mounting driving lites to the tip overs on the front, I might have something for that.
Riders cup holder that mount to the front of the resivors, that is mounted using the mirror holes, I made my mount, I could make more.
I am not trying to take anyones thunder, parts or ideas , just trying to help get some cool stuff out. |
Posts: 215 W'ford Tx | Sounds good jb for the cup holder but us with 08s don't have that option. I've seen one on eBay for $70 but don't know exactly how it works and don't want to pay that much to find out if it works or not. |
Posts: 249 Phenix City AL. | A regular drill, and a tap set, would allow you to drill and tap your 08, I have 08 controls on my 09, that I drilled and tapped, ride over to Alabama, and I will do yours lol |
