| Stopped into "Honda East" in Maumee Ohio for my first service on 2012 CCT. While waiting, I talked to the parts Mgr. P.J. I told him I've heard that you can't sell a bike in Europe without a fork lock and asked how Victory sells the CCT over there. He said Victory makes a fork lock Pt# 4013053-266. If your bike has the rubber knock out plug in the middle of the top tripple tree (mine does) it should work. It costs about $250.00 and he thought it came with new lock cylinders for the gas tank and ignition so they would all be keyed alike. Didn't think to ask what about the trunk and side bags. Anyway, I would like to have a fork lock and will probably order the kit this fall for a winter project. Will keep you all posted. Let me know if anybody else is brave enough to jump in and try it first. |
| That Part number comes back to a fuel tank lock...where ignition key open to fuel your bike up....NOT a fork lock.
Just an FYI. |
| NOEMTZ you are partly correct in that if you order the part (I did and have it in my hand) you will get a new gas cap, ingition, and the Fork lock all keyed alike. That way you can only have one key. That is why it is so expensive. However, if you have the trunk and saddlebags, you still are stuck with 2 keys. The fork lock is a solid looking part and should work well. The main problem now is that it didn't come with bolts or any instructions. Am in the process of trying to find out what size bolts are needed. Very difficult to get in there. |
| I have seen a part number for the fork lock kit that has the trunk and saddlebags locks included, here is the part number 4012944-266. And the description from the parts listing, ASM-IG,FLCP,TRNK,FRK,SBLKS,BLK ([Int'l] )
4012944-266 $277.99.
As stated earlier her is the part number without the trunk along with the description. Part # 4013053-266, and the description from the parts listing, ASM-IGN/F CAP/FRK LOCK,INT,BLK ([Int'l] )
4013053-266 $277.99
I know this is a bit late to post, but I hope this helps someone. |
| How about some pictures of those locks. Some before you mount and mounting them would be cool. Thanks. |
Posts: 118 Capitol Region of NH | I wonder if there is a way to send them your current key number and they can send the fork lock keyed to everything already on your bike. |
| I locksmith can probably match up the bag locks to a new fork lock. It would probably be easier to match up the new fork lock to your existing locks. |
