Posts: 576 , IA | can someone post a synopsis on fixing the rear break on a vision. its been talk about alot. took to a vic shop today and of course they never heard about said problem. its the one where there is a air leak causeing the pedal to just go down. fluide and pads r fine. thought i read it was rear master cylinder and some hose. Any help would be nice so i can explain it to their shop guy thanks dennis | |
| <p>Have never read were any one has figured out where or why. Have read where they have replaced master cylinder and lines and so on but No one has pin pointed the problem. Most just bleed right front caliper using the center bleeder. Brakes come back to normal This happened to mine once bleed the the front caliper and have never had a problem after that. Buy the way you should add year and where you live</p><p>sorry I missed where you said 08</p>
Edited by johnnyvision 2013-04-27 6:00 PM
| I think you have it. There was an issue with the rear brake line, where it would allow air in the line and not leak fluid. It still makes no sense, but I replaced my line, bled the brakes and no more issues. | |
