Hydraulic clutch loosing pressure
XRsteve
Posted 2013-11-23 8:44 AM (#149092)
Subject: Hydraulic clutch loosing pressure
Georgia, west of Atlanta
The hydraulic clutch on my 2008 is loosing pressure. If you pull the clutch all the way in it's fine but if you have to modulate it for any reason like being #2 on a hill at a stop sign it feels week and engages early. Fluid must be leaking past the pressure piston. Anyone else ever have this problem ??
Posted 2013-11-23 10:00 AM (#149095 - in reply to #149092)
Subject: Re: Hydraulic clutch loosing pressure
Steve, just bleed it out and replace the fluid, most likely the problem. I've had to change mine at least twice since I had the Vision. I'm ready to change it out again.
I had this problem with the Honda and went about 1,000 miles and had to pump it up to get it to get the clutch to release. Fluid was old and when it got hot, it was not doing the job. I was riding interstate so the stops were just for gas and it would hold for the few moments that I needed it. It was dead after few miles, but some pumping brought it back to life. Oh, the memories.
XRsteve
Posted 2013-11-23 11:50 AM (#149106 - in reply to #149092)
Thanks brother..........I'll try it out............
TLane1911
Posted 2013-11-23 8:44 PM (#149125 - in reply to #149092)
Maylene, AL
It could be the slave cylinder. My clutch was doing the same thing on my 2008 Vision.
ingle51
Posted 2013-11-24 5:17 PM (#149139 - in reply to #149092)
Subject: RE: Hydraulic clutch loosing pressure
NE Florida Jacksonville
Keep in mind that the hydraulic fluid will pick up moisture over time and that is the major problem. When the fluid get hot the water will turn to vapor and you'll loose the the fluids ability to keep the pressure up. I change my brake and clutch fluids every two years.
Posted 2014-02-01 5:48 PM (#150950 - in reply to #149092)
Sacha45 - 2014-01-31 10:50 PM good job thanks for the sharing..... http://plagiarism-checker.info/
Hey I have infected computer not ass hole
rwilly
Posted 2014-02-01 5:56 PM (#150952 - in reply to #149092)
seattle, wa
That is the second time that link has been spammed here.
I would think the mods would have deleted the post by now.
Posted 2014-02-05 7:04 AM (#151037 - in reply to #150952)
rwilly - 2014-02-01 6:56 PM
Can only be on one place at a time. Thanks to those who post the alert so I can take action. Complaining that I'm not acting quickly enough does not help.
Street Eagle
Posted 2014-02-05 11:04 AM (#151045 - in reply to #149092)
Manchester, CT
Jeff..you have done and do an AWESOME job running our site!!!. Everytime I've come across a malicious or inappropriate content you rectified the issues immediately!!!
I've been an umpire for many years. Any time someone over steps boundaries, I walk over with my ball clicker and offer to change places...you know, I've never had any takers
MaddMAx2u
Posted 2014-02-06 5:33 AM (#151078 - in reply to #151037)
Orlando, FL
Jedi Jeff - 2014-02-05 8:04 AM
+1 Go Jedi Jeff~!!
Posted 2014-02-06 7:36 AM (#151085 - in reply to #149092)
how's the clutch XR?
