start-push button
Banjodan
Posted 2014-06-15 9:28 PM (#158363)
Subject: start-push button
sometimes I have to push my start button two or three times for it to turn over. is this a sign of failure? or can it be cleaned? replaced? any ideas?
Posted 2014-06-16 10:29 AM (#158376 - in reply to #158363)
Subject: Re: start-push button
banjod, are you pulling your clutch handle in, even if the bike is in neutral? Mine does this all the time and probably started about the 2nd or third year of ownership. I suspect it is the clutch neutral switch and not your button on the handle bar. Since I'm usually dead wrong about everything else, then it is not this at all and entirely something else. Now that I responded you'll get someone to chime in with an entirely different answer. Hope you'll get the answer you're looking for soon.
Posted 2014-06-17 7:23 PM (#158415 - in reply to #158363)
Check your battery cables
Clutch switch p/n 4011852 hope your sitting down for this $65 bucks. Starter switch p/n 4011357-067 $ 131 bucks
I looked up parts on Vic's web site.
You wouldn't have to open housing just spray in some con tack cleaner
Banjodan
Posted 2014-06-17 8:30 PM (#158417 - in reply to #158363)
thanks guys....
boatsrfun
Posted 2014-06-18 6:26 AM (#158423 - in reply to #158363)
I had the same problem. It was the starter solonid.
