Posts: 447 Northeastern Penna. |
I have my 08 vision 1 week now.Took it out yesterday,put on 175 mi.Noticed when I shut it off,there would be what sounds like a whistling sound coming from the front of the engine,lasting
about 10 min.Also,later in the ride,the idle would occasionally rev up high,then slow down.This
was most noticeable when idling at a stop.
Has anyone experienced these things with their vision?
I posted this message last night,with only 1 reply from Bearcat,who thought the idle thing
could be an air leak.He never heard of the whistling sound.Anyone else experience these
quirks? |
| Try pulling your gas cap off when you hear the whistling and see if it stops, it may just be your fuel tank venting. |
Posts: 261 Sugar Land, TX (Outside of Houston) | I agree on the Fuel Tank Cap try - 10 minutes is a long time to hear it unless something is under pressure and venting ever so slightly.
I have actually heard Batteries "Sing" or whistle when they get over charged, but I doub't that is happening. More like a pressure relief. But mine does not do that.
I do, however heard a mutiple click, click, click for about 3 seconds after turning off the bike. I assume it is the fuel pump shuting down but not sure. Will ask Service unless anyone knows what that sound is as well.
Richard |
Posts: 293 Arkansas | The manual will tell you that the clicking sound is nomal.
Posts: 72 Eden Prairie, MN | rmclarty - 2008-08-17 3:39 PM
Richard
The bike has an IAC. Idel Air Control is a stepping motor that resets itsself each time you shut off the engine a couple of seconds after you turn the key off. This is the clicking sound and is normal.
My Kingpin would meow like a cat after shutting down and it would do this after a ride or even when the temperature changed. I haven't noticed my vision doing it, but if it was I wouldn't have thought twiceabout it. It wouldn't hurt to have the dealer listen to it next time your in.
Posts: 261 Sugar Land, TX (Outside of Houston) | Thanks for the Clicking Information. I was just going to start telling people that it has an Auto Re-Wind and was winding itself up for the next outing. |
