Posts: 5 Ponca City, OK | I will pick up my 2008 Vision tour Comfort Saturday.
Anyone else from the Ponca City, OK area?
Do J&M headsets plug into the vision's sound system? |
| Congrats on the purchase. Not sure about your other question. |
Posts: 1308 Sand Rock, AL United States | congratulations ! I can't answer the audio question and I don't live in Ponca City but I do stream a live radio broadcast daily to my work computer of a Christian station that is based in Ponca City called The House FM. Enjoy your new ride, there is nothing like the Vision. |
Posts: 341 West Salem, WI United States | Welcome to the Vision. If you already have the headsets, then I think you should contact J&M, if I remember right they have a harness you can purchase to make those connections. |
| get owners book and read it you'll find out how to check oil |
Posts: 8 VA Beach | Congrats. Yes a J&M headset will plug in in the Vision if you have a 7 pin connector. Depending on your configuration you may have to change the lower cord or the whole cord to a 7 pin configuration. The vision uses the same J&M 7 pin connector as the CAN-AM; a Goldwing connector will not fit. I am unsure about the HD connector.
JC |
Posts: 1632 Jasper, MO | funhunter63 - 2016-02-19 3:09 AM
Congratulations.
Yes, they do. Just get the lower half cord to match the Vision.
I use the same headsets on two different brands of motorcycles. Just use the appropriate lower cord.
Ronnie |
