Need connector harness for GPS, can you help?
divesharc
Posted 2009-03-11 12:00 AM (#29997)
Subject: Need connector harness for GPS, can you help?
VA
Hey guys, for those of you that have the Victory/Garmin GPS, I need your help. On the right side (from driver's perspective) there is a short cable that ends in a plastic male end. It has several wires running to it, black/white, black/pink. 4 in total. I believe this is the harness for the GPS connection. I was hoping that maybe this looked like a similar harness that some of you may have seen before. I want to buy a harness and splice into it to make a connection for my own GPS. I can cut the wires, but if it is a standard connector, than I'd like not to cut it. I contacted my dealer and they already told me that this only comes with the GPS kit. Can anyone help? I appreciate it.
Marc
g1nomad
Posted 2009-03-11 11:13 AM (#30013 - in reply to #29997)
Subject: RE: Need connector harness for GPS, can you help?
SC, Bluffton
Look Here:
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=2064&pos...
The 2nd post down, from SPOCK gives some detail to the 4 wires.
I'll be mounting the ZUMO 550 sometime. I use it on our other bikes with the way off Japanese speedometers.
Herb
Travler
Posted 2009-03-11 4:09 PM (#30030 - in reply to #29997)
SE Florida
The connector is an AMP Mini Multilock connector you can find information about it on the AMP web site AMP is owned by TYCO electronics www.tycoelectronics.com I was able to track down a supplier who is supposed to have them Sager Electric 800-724-3780. I am attaching a drawing with the part numbers hope this helps.
Attachments AMP_Connector.pdf (36KB - 29 downloads)
Teach
Posted 2009-03-11 7:45 PM (#30034 - in reply to #30030)
Subject: Re: Need connector harness for GPS, can you help?
Just under the nose plate (in front of seat) is a grey plug with two wires, one pink and grey and I forget the other color. It is an aux power lead and works great for hard wiring the GPS power harness. If you need sound as well then never mind, lol......
Joe H
Posted 2009-03-11 9:25 PM (#30035 - in reply to #30034)
Eyota, MN
Call Garmin directly and they will send you one, the guy told me it was an $8.00 part. That is where I got mine.
divesharc
Posted 2009-03-11 9:51 PM (#30039 - in reply to #29997)
VA
Guys, thanks for the help!! That is exactly what I was looking for. I might call Garmin directly too, that might be easy as well. Looking to make my self a quick disconnect power and audio. Either way, this will save me from cutting up the factory harness.
I'll look at that thread from Spcok as well. I just need to make the harness and figure out how I'll make it easy to remove. I don't keep the GPS on the bike all the time. Thanks again.
