Posts: 43 CASHTON, WI United States | IS IT JUST ME OR IS ANYONE ELSE NOT ABLE TO LOCK THEIR HANDLEBARS? AM I DOING SOMETHING WRONG? I HAVE NEVER BEEN ABLE TO LOCK THEM. THE PROPER PROCEDURE IS?
THANKS FOR THE HELP!
RIDE SAFE
HWY27GUY |
Posts: 965 New York State | I have no problem locking mine...Unlocking them can be a problem though. |
Posts: 166 Bullhead City, AZ | Never had problem. Even locked them by accident one time. From sitting turn handles to left, push down on key and turn counterclockwise, pull out key. |
Posts: 8144 New Bohemia, VA | loren2 - 2009-03-18 9:15 PM Never had problem. Even locked them by accident one time. From sitting turn handles to left, push down on key and turn counterclockwise, pull out key. Highwayman, is this your method when trying to lock the front fork? The Vision has a single point of lock and that is fully to the left, and no other. |
Posts: 3006 San Antonio, TX | hwy27guy,
After locking you must unlock. To unlock: insert key and push down, turn clockwise to OFF and then let the key spring up. From there you can turn the key to ON and ACC if you wish.
If you turn the key to lock without pushing down, the GAS door will open.
I lock mine at work every day.
Ride Safe! |
Posts: 212 Tavares, Fl | Mine is turn the handlebars to the left as far as they will go. Push down on key and turn left. Jiggle handlebar and key simultainously till the lock engages. To unlock, jiggle handlebar and key while turning key to right... |
Posts: 173 Prescott Valley, AZ | It is not "just you". The day I rode the Vision home the neighbor came over to see it and I could NOT get the bar unlocked. Of course he is an old HD man from way back. Try as I might I could not get the damn thing unlocked. Went back to the garage an hour or so later and big as life it unlocked first try!!!! YES, I was pushing down on the key and moving the bar as much as it would move, it did not open the first time. I took it back to the dealer the next day and told them so they tried it and of course it worked just fine! Since then it has worked flawlessly! I figure I must have been holding my mouth wrong or something cause it works fine everyday at work now. So it ain't you, it will be fine after a couple tries I'm betting!!
Ride Safe, Ride Often!!
Posts: 97 Brighton, Colorado | What RLREED said. |
