Posts: 92 Eau Claire WIS. 09 vision | does any one know the blub # for the front turn sig. not the victory #s the automotive ones i know the rear is 3157. i want to change them all to led thanks dave.... |
Posts: 92 Eau Claire WIS. 09 vision | nevermind i pulled it apart and looked, its also a 3157 thanks dave |
Posts: 68 Cabot Arkansas | you will have to remove the entire front turn signal assembly to put the leds in the inside running light |
Posts: 92 Eau Claire WIS. 09 vision | i got the blub outand back in with a little finess hopefully it will work with the led...dave |
Posts: 68 Cabot Arkansas | i bought the 31 led bulbs and they would not make the turn into the light assembly, but well worth the work for the amp savings |
