Posts: 3773 Pittsburgh, PA | A little while ago, maybe it was more than alittle while ago. i read where someone posted dyno numbers.. i think there was like 4 numbers total and it went something like this
stock
s1l1
s1l2
and something else...
does anyone have them numbers? |
Posts: 1290 Ruskin, Fl | Not what you are talking about, but I poted mine a short time ago. Got 85.25 hp and 101.5 ft lbs of torque at the rear wheel. The thread is with the dyno slip is: http://www.vision-riders.com/bb/forums/thread-view.asp?tid=2903&pos...
Edited by cw1115 2009-04-09 9:04 PM
Posts: 3773 Pittsburgh, PA | thanks.. was your dyno run with the s1l1 fuel injection map? i ask cause i noticed you said a paper air filter.. |
Posts: 1290 Ruskin, Fl | Yes. I took out the filter that comes with the upgrade to clean and oil it during an oil change. It was rusted and the element was discolored. I put the paper one in until I could look into replacing it and forgot about it. |
Posts: 174 Edmonton, AB | Well if it helps all the power hungry demons remember where they started from....Here is the Dyno Chart from my stock vision. 82HP & 99Ft/Lbs
One more that should definitely be added to the list for comparison purposes is a Vision with Lloyd's Cam, Intake, and Fuel Controller.....If that set-up doesn't feed the demons then I doubt that anything will.
 (2008 Victory Vision (Stock) Dyno Results.jpg)
2008 Victory Vision (Stock) Dyno Results.jpg (57KB - 4 downloads)
| I have the full Lloyd's upgrade and Big Honkers for Exhaust.
Came up with 111HP/111TQ in Daytona. |
Posts: 154 Cabot Arkansas | #57 - 2009-04-10 2:41 PM
Do you have your dyno sheet to post ? I would love to see the power and HP curve on that setup.I have looked at Lloyd's site and can't find one .
Thanks |
Posts: 1340 Gainesville Fl Home of the Gators | http://www.vision-riders.com/bb/forums/thread-view.asp?tid=2824&pos...
Thias thread has charts on....
stock
Stage1
Cams
Edited by kevinx 2009-04-25 6:14 AM
| Maverick,
I lost my sheet on the trip back from Daytona.
As I remember it was dam flat all the way through.
Having some more stuff done to it courtesy of Lloyd.
Will make sure to post those numbers. |
 (Vision - VM1- VIP- VFC 112-114.jpg)
Vision - VM1- VIP- VFC 112-114.jpg (53KB - 3 downloads)
Posts: 106 L.I., N.Y. | llioyd is that sock or your cams, Victory is putting out this ad now with the stage 2 cams. http://www.polarisindustries.com/en-us/Victory/2009/Pages/engine_la... |
| Lloyd,
What mods? |
Posts: 3006 San Antonio, TX | DO not forget that Victory is showing the dyno numbers from the engine shaft not the rear tire. All of the dyno numbers here are from the back tire.
Ride more Ride safe |
Posts: 87 Lusby,Md | who cares,just ride and enjoy! |
Posts: 1340 Gainesville Fl Home of the Gators | slowryder - 2009-04-28 7:50 AM
Those numbers are taken at the crank, and are about 14% higher then if measured at the wheel. The Lloyds dyno was measured at the wheel, and though I have not seen numbers that high in person; different bikes can make higher, or lower with the same parts
Edited by kevinx 2009-04-28 6:13 PM
| I finally found my Dyno. Had put it in a place so as not to lose it, just forgot where that was.
My scanner is pissing me off, will have the wife scan it tomorrow morning at her office and then will post. |
| Hopefully this works. If not, it is supposed to be my graph.
 (Dyno Graph.bmp)
Dyno Graph.bmp (45KB - 12 downloads)
| Trying again.
 (Dyno Graph.bmp)
Dyno Graph.bmp (59KB - 9 downloads)
