Posts: 447 Northeastern Penna. | Had the Vision out all day and when we returned home in the evening, the riders behind me noticed I had no brake lights. Before I departed this morning, I had put my trunk back on.I checked that wiring harness under the rear portion of the seat,that has to be disconnected if you remove the trunk.It does not control the brake lights. Checked the fuse,still good.Before I troubleshoot further tomorrow, has anyone experienced this ? | |
Posts: 404 San Antonio, TX United States | Wjoel, Please take a moment and check the service manual section on electronics and turn signal section in particular. You will find a section that tells you how to enter the diagnostic mode for your turn signal module. This will help you narrow down where to look for problems. If you do not have a manual, please look at http://www.mediafire.com/2008visioninfo You can find a copy of the manual to look at. | |
