Glove box won't stay shut
RedDog
Posted 2009-05-09 8:14 PM (#34133)
Subject: Glove box won't stay shut
OHIO
  It just happened.  Door will not stay shut even with the ignition in the lock position.  With the door open and turning the key to the lock position you can see the lock rod move out, but when you shut the door it does not hit the lock rod.  I would think it should hit the lock rod, thus not close when you have the ignition in the lock position.
  I shut the door and it just pops right back up.
Posted 2009-05-09 9:02 PM (#34138 - in reply to #34133)
Subject: RE: Glove box won't stay shut
RDO, check the latch on the door, it is a positive lock when that pin slides through, the only way it wouldn't if it had nothing to hold on to. You may need a new door. Just a thought.
RedDog
Posted 2009-05-10 10:45 AM (#34198 - in reply to #34133)
OHIO
Varyder,
         Thanks for the reply, but my door looks fine.  It doesn't matter wheather you lock the door or not, it pops right back open.  To me it looks like when you lock your door, the locking pin slides through a small hole in your door.  My locking pin slides back and forth with the ignition switch, but is not going out fall enough to go through the hole in the door.  If it would go through the hole in the door then the door would stay down, but only with the ignition locked.
         I guess I may have to take the center console off to take a closer look at the switch.
Posted 2009-05-10 2:51 PM (#34221 - in reply to #34198)
Then it would be the lock switch on the bike, it seems to be similar to the home stereo cabinet doors, maybe it is just needs a shot of WD40. Just another suggestion.
RedDog
Posted 2009-05-10 9:10 PM (#34262 - in reply to #34133)
Subject: Re: Glove box won't stay shut
OHIO
I've got in shut, but am afraid to open it again..... Went for a little ride today just to make sure it stays shut and it did.
mrwatson
Posted 2009-05-10 9:47 PM (#34269 - in reply to #34262)
Subject: Atom Bombs
Aubrey, TX
I am just curious how much the sound improved once you swapped the tips from stock to the gatlins?..just curious what to expect?
Thanks,
Mike
g1nomad
Posted 2009-05-11 11:41 AM (#34320 - in reply to #34133)
SC, Bluffton
RedDog - 2009-05-09 8:14 PM
This is going to sound silly, but it almost sounds like you tried to shut it AFTER you locked the handlebar. It won't shut this way. You probably know that, but I thought it was worth typing.
Herb
RedDog
Posted 2009-05-11 7:47 PM (#34347 - in reply to #34320)
OHIO
g1nomad - 2009-05-11 11:41 AM RedDog - 2009-05-09 8:14 PM
  It just happened.  Door will not stay shut even with the ignition in the lock position.  This is going to sound silly, but it almost sounds like you tried to shut it AFTER you locked the handlebar. It won't shut this way. You probably know that, but I thought it was worth typing. Herb
   Your right Herb.  It does sound silly, and no I did not do that.     Thanks for the thought Herb.
   My door will close down even with the ignition locked.  I do not think it should close with the ignition locked and the door open.  The  door should hit the locking pin, but mine does not.
Member No. 1
Posted 2009-05-11 8:02 PM (#34349 - in reply to #34347)
Under the Rule of Jedi - Masshole
g1nomad,
Sorry if this sounds stupid, but is the piece that latches into the pin lock still attached to the glove box door?
Anyway of taking a picture and posted what the tab looks like?
RedDog
Posted 2009-05-11 8:27 PM (#34351 - in reply to #34349)
OHIO
Member No. 1,
                         I think you meant me, not G1nomad.     The underside of my door looks fine.  I will take pictures as soon as I build up the courage to open the door again!!
                         And no it does not sound stupid, and that goes for everybody's replies!
                         Thanks,
Member No. 1
Posted 2009-05-12 5:58 PM (#34414 - in reply to #34351)
Red Dog,
Not sure if this will help, but here is a link to some close up pictures I took of the latch and catch.
Click on the picture for a larger image.
http://gallery.me.com/petefredette#100359
RedDog
Posted 2009-05-12 7:32 PM (#34417 - in reply to #34414)
OHIO
Member No. 1,
           Thank you very much for taking the time for the pictures!!
            I think I have 2 issues going on.  In picture (catch 1) your locking pin looks like it is even with the hole for your door to go into.  Mine is back slightly, and I think that is why my door will not lock.  I bet if you try to shut your door with the ignition locked, you will find that you cannot.
           My second issue is the where the door latch goes into the  switch by the screw.  When my door is open, my switch pops up (like picture 2 or 3).  But when I shut my door, the door  goes into the switch, but the switch will not stay down with the door in it.  It you can gather what I am saying.   The switch will pop back up, thus releasing the tab on the door.
Member No. 1
Posted 2009-05-12 8:07 PM (#34421 - in reply to #34417)
You are correct, you shouldn't be able to shut the door if you lock the ignition first as the locking pin is in the way.
I understand part two of your question. My question to you, if you push down the catch by hand does it stay down or pop right back up? If it does then it sounds like you have a bad catch.
Hard to trouble shoot over the internet! Can you email your bike to me so I can have a better look?
tralphaz
Posted 2009-06-14 8:05 PM (#36697 - in reply to #34417)
RedDog - 2009-05-12 4:32 PM
Member No. 1,
This might sound stupid but check it out anyway, I had issues where my door would hang when I tried opening it (the pin was out too far) so I pulled the console off played around with the cable and slightly rerouted it, the reroute pulled the pin in enough that I no longer have an issue with the door.
RedDog
Posted 2009-06-14 8:56 PM (#36701 - in reply to #34133)
OHIO
Thanks for the reply.  I may have to check that out as I am not going back to my dealer.
