Trunk removal panel
southjerseyrider
Posted 2009-06-01 9:41 AM (#35752)
Subject: Trunk removal panel
Vineland, NJ United States
I purchased an 08 Visioin Tour Premium used. I love it and have put about 2,500 miles on it already. It came with the trunk installed but the seller did not have the trunk panel necessary to run with trunk removed. What exactly do I have to order to get what I need to remove the trunk and run as a "street" model?
Thanks
ED
Member No. 1
Posted 2009-06-01 9:58 AM (#35754 - in reply to #35752)
Subject: RE: Trunk removal panel
Under the Rule of Jedi - Masshole
Just order the cover plate from the dealer, he might even stock it. When you buy the Premium bike, it does not come stock with the cover. You have to buy it separately.
Lotzafun
Posted 2009-06-01 10:23 AM (#35755 - in reply to #35752)
Rockford, IL
The part numbers are different depending on what color the bike is. But be careful....apparently there is a "factory" part number for each color and I think its around $225 or so. And there is a Pure Polaris part number for each color and it is around $110 (or less). They are the SAME part, SAME color...just different prices.
The Pure Polaris part numbers are......
2876888-266 - Black
2876888-554 - Midnight Cherry
2876888-245 - Super Steel Gray
?????????-??? - Ice Blue
If anyone has the Ice Blue Pure Polaris part number please post it.
Edited by Lotzafun 2009-06-01 10:26 AM
southjerseyrider
Posted 2009-06-01 2:34 PM (#35771 - in reply to #35755)
thank you, found it and ordered it for $99.99
