| Going on a trip and installing the trunk on my 09 tour P. Connected the main harness, but have a 1 wire connector that comes off the trunk side of the main harness connector. Can not find the female side that it plugs into. Any help would be appreciated
Posts: 460 Centennial, CO | I had the same problem until I realized that it is not used until you add some other things like a CB and such.
Hope this helps!
If I am wrong...PLEASE correct me as I do NOT want to be posting incorrect info. |
| thanks,
took the trunk off last weeked and wondered myself what that little round plug was. ya think they would mention it in the instructions. |
Posts: 203 Rapid City, SD | I have the CB and I think its the antenna cord. One issue I had was there was BARELY enough slack on a good day. The trunk half the that wire got stuck up in the cavity and I had to remove the back seat pad to fish it out. Kind of a pain. They could have made it a little longer. |
| Thanks, after I realized everthing worked without it being pluged in, I thought it might be for an accesory! |
Posts: 74 Lehigh Valley, Pa | The wire in question is for the CD changer. |
