Posts: 204 guelph ontario | On a recent trip I notice that after the bike was good a hot that when I turned it off-the oil pressure light came on at about 1/2 brightness for about 5 seconds and then shut off. It doesnt do it when the bike is not hot. So only after and hour or so of riding does it do it. The Vic mechanic said I should worry if it come on while riding and not when its off-Da? |
Posts: 311 Atlanta Area | The oil light should be on anytime the key is in the run position but the engine is not running. ie; before you hit the starter button and after you hit the kill switch...
If it lights up when the engine is running, you got big time troubles... |
Posts: 204 guelph ontario | It lights up at 1/2 brightness when the bike is off and the key is removed. I know that when the ignition goes on that the light goes on but it does so at full brightness. |
Posts: 3006 San Antonio, TX | Replace the oil pressure sensor at the bottom left of the engine. Check the wire for a tight fit.
Mine will half light and stuff when wet. My oil pressure is fine. |
