Vibration on test ride
emanIA
Posted 2009-06-17 9:12 AM (#36936)
Subject: Vibration on test ride
Des Moines
Hello - new member here and first post. My wife and I test rode a 09 Vision comfort the other day and while I was truly in love with every aspect of the thing, my wife complained of a vibration she felt through the trunk that just drove her nuts. So bad that she almost had me pull over so she could get off. My friend was following us and he said he could see the trunk lid vibrating as well.
I know that can't be normal as I've never seen anyone complain about it online and the sales gal said she hadn't heard anyone complain either. We checked the truck when we got back and nothing seemed loose that we could tell. Has anyone else had this issue?
We're riding another one from a different dealership this afternoon, so hopefully all will go well and I'll get the green light to but it, but she obviously isn't going to say yes to a $20,000 bike she can't ride on. As we all know, if momma ain't happy, nobody's happy.
I have to believe that it had to be something with that particular bike. The more she described it, the more it sounded to me like it threw a wheel weight or something. Vibration was worse the faster we went and if we weighted the trunk down with my jacket it was better.
mgoblue
Posted 2009-06-17 9:24 AM (#36939 - in reply to #36936)
Subject: Re: Vibration on test ride
I know this probably doesn't help but i've never had that issue. My wife LOVES the bike and we really don't keep the trunk on unless it's over night(storage). Great Bike, make sure the dealer is gonna stay around for awhile.
Posted 2009-06-17 9:31 AM (#36940 - in reply to #36939)
my guess is that the lid needs to be adjusted to close better to eliminate that vibration. I know my 08 vibrates but the wife doesn't complain that it does as it is probably quiet enough not to create an annoyance.
emanIA
Posted 2009-06-17 9:46 AM (#36943 - in reply to #36936)
Des Moines
Thanks. I figured it was something with that particular bike. It wasn't a noise she noticed, it was actually vibrating against her back, like a massage chair only in a bad way (she hates those anyway). I didn't really notice anything, but I'm coming off a V-Star 1100 which is a buzzy bike at speed anyway, so maybe I did feel it a little and just figured it was normal v-twin vibration. It was 100 times smoother than the V-Star, however. Like going from a VW to a Cadillac.
emanIA
Posted 2009-06-17 9:46 AM (#36944 - in reply to #36936)
Des Moines
Sorry, double post.
Edited by emanIA 2009-06-17 9:47 AM
bigwill5150
Posted 2009-06-17 9:48 AM (#36945 - in reply to #36936)
Reno County, KS
Vision's aren't for everyone. The V-twin will vibrate compared to something like a Goldwing. Just a fact of life. It all depends on what you want from a bike. All baggers have their ups and downs I guess.
wroman
Posted 2009-06-17 9:59 AM (#36950 - in reply to #36936)
Gettysburg, 2008 Tour Premium
The trunks are removable and maybe the bolts were loose. My bike vireated more when new than now a 2,500 miles.
Walt
ElroyJ
Posted 2009-06-17 10:23 AM (#36955 - in reply to #36936)
Subject: RE: Vibration on test ride
Centennial, CO
The trunk should not be vibrating to the point of annoyance...period! Something is wrong...
My trunk was super quiet and vibrated as much as the rest of the machine for 6500 miles and was NO problem at all. I had the CB installed and now it rattles like it has marbles in the bottom. And yes, as you may have guessed, its in the shop as I type getting all the details buttoned up.
So, try the other dealer or even ask to ride a different Vision because what you experienced is VERY abnormal.
cjnoho
Posted 2009-06-17 10:58 AM (#36960 - in reply to #36936)
So Cal
I would try another bike somethings not right. With a passenger leaning back, the trunk should rattle less.
VisionTex
Posted 2009-06-17 11:32 AM (#36967 - in reply to #36960)
LaPorte,Tx.
My wife has ridden alot on the back of my Vision and has never mentioned vibration through the trunk or seat. Try another Vision on a test ride.
Posted 2009-06-17 4:21 PM (#36985 - in reply to #36936)
Check the air in the rear shock. If it is too high +50 lbs and the rider and passenger are light - 300 lbs combined or less, the vibrations will be amplified a bit.
It takes a bit of trial and error to find the proper pressure for two up riding.
Ride Safe
Edited by radioteacher 2009-06-17 4:21 PM
ElroyJ
Posted 2009-06-17 4:42 PM (#36986 - in reply to #36985)
Centennial, CO
radioteacher - 2009-06-17 2:21 PM
Ride Safe
I ride two up a lot and then single a lot too. I am always changing up my shock. You mention that it takes practice. Do you not follow the sticker saying how much pressure for weight? This works fine for me.
Posted 2009-06-17 5:39 PM (#36988 - in reply to #36936)
My wife has a bad back. If I set it to the chart levels the road vibrations are a bit firm for her back. I normally set it about 3 to 5 lbs less then the chart for two up.
I set it to the chart for just me.
If I am riding solo in the twisties, I do the chart plus 5 lbs for a firmer ride in the corners.
Ride Safe
Edited by radioteacher 2009-06-17 5:40 PM
emanIA
Posted 2009-06-18 10:17 AM (#37022 - in reply to #36936)
Des Moines
Update - we rode the bike at the other dealer and she was MUCH happier. 09 Vision Tour Comfort has now been purchased and I'm waiting for them to uncrate it and set it up and accessories have been ordered. Woohoo! This is gonna be a long few days.
DesertJim
Posted 2009-06-18 10:34 AM (#37024 - in reply to #36936)
Scottsdale AZ
Congratulations!!! You will be VERRY HAPPY with the Vision!
cw1115
Posted 2009-06-19 7:02 AM (#37089 - in reply to #36936)
Ruskin, Fl
My wife complained about the trunk "rattle" from the beginning. Now at 16K it's bothering me. Ive noticed a grove started to wear in the flat spring loaded think. Will try adjusting today.
VisionTex
Posted 2009-06-19 8:51 AM (#37097 - in reply to #37089)
LaPorte,Tx.
My wife also complained about the noise, but after putting extra sealer on the rubber parts to make it latch tighter and with her sitting on the bike with her back to the lid pad, I came to the conclusion it was something on the lid or trunk. I found it to be the speaker covers rattling, double stick 3M foam tape solved the problem. On a real hard rap like going over a rough RR track I can still get some rattle, believe it is from the black trim on the lid. I think some double sided foam tape here will also help.
