gas smell
nightrider
Posted 2009-07-06 6:54 PM (#38165)
Subject: gas smell
On our usually Sunday ride my buddy who was behind me all day said that when he was close behind me he got a gas smell from my exhaust. I didn't smell anything and the bike ran ok anyone had that type of problem
sonicbluerider
Posted 2009-07-06 7:31 PM (#38166 - in reply to #38165)
Subject: Re: gas smell
, IA
come on>>> fess up<<<< u know u where cutting the big ones from all the food u ate saturday night
a99miata
Posted 2009-07-06 7:47 PM (#38170 - in reply to #38165)
northwest florida
BEANO!!!
1atom12
Posted 2009-07-06 8:11 PM (#38174 - in reply to #38165)
Atlanta Area
Nightrider, did you recently fill your gas tank before you bud smelled the gas? Could be gas venting out of the overflow tube or leaking around the gas cap gasket if you overfilled...
exharleyrider
Posted 2009-07-06 10:18 PM (#38184 - in reply to #38165)
Victory has a known problem with the gas caps. they replaced mine under warrantee. do it now before gas starts leaking on everything
Necktie
Posted 2009-07-06 11:03 PM (#38186 - in reply to #38165)
Prescott, Az
Mine was pouring out after each fillup. I saw gas getting my right boot wet. The dealer replaced the cap with the new one that has a rubber lip and no more problem. I hear Victory stamped some filler tank necks to thin. If they get too bent out of shape Victory will replace under warranty. You cannot prop the gas nozzell against the filler cap even a little bit because they will bend the neck out of shape.
Edited by Necktie 2009-07-06 11:05 PM
Cometman
Posted 2009-07-07 11:30 AM (#38207 - in reply to #38165)
Simi Valley, CA
Twice I have had gas leak after fill-ups, both times I had to stop and re-do the gas cap. This sounds like an issue with the seal of the gas cap.
Tim
Blue Sky Guy
Posted 2009-07-07 12:42 PM (#38220 - in reply to #38165)
scotts valley, California
Mine seemed to get well on its own.
dondor959
Posted 2009-07-08 7:08 PM (#38300 - in reply to #38165)
If I fill mine too full it comes out the overflow. If I'm careful and noe comes out I'm good untill I hit the first twisty and lean too far to the right
dondor959
Edited by dondor959 2009-07-08 7:09 PM
