Posts: 460 Centennial, CO | Hey all,
I am curious...how far did you get on your first set of tires? I made 10k and probably could have gone to Sturgis and back (1500 miles round trip including day trips while there).
I opted to put new tires on BEFORE I left for Sturgis and after all the rain, etc., AND the better handling, I am glad I did it. I found that when I leaned the first time it took MUCH MORE lean to get the bike to turn than after 9k on the tires. Although I felt like I was leaning farther, I was definitely more comfy in the turns. I had no problem dragging my highway pegs with the new tires. Prior to the new tires, I was beginning to wonder if I was just getting older and more nervous about turning.
Is 10k about right? The dealer said I am one of the lucky few that got more than the 7500 he has been seeing pretty regularly. I usually get 10k ~ 12k miles before replacing on any bike I owned with exception to the crotch rocket I owned for a while. That bike was good to about 5k but I also rode that bike HARD!
I did opt to go with Lops again due to the 1/2 price for the tire(s) if installed by the dealer. It still ran me close to 430 bucks. Is this price about right? All of my other bikes I could have tires replaced for roughly $200. Is the time to remove the rear tire really that bad which could have cause almost 200 more in labor? |
Posts: 562 SC, Bluffton | ElroyJ - 2009-08-19 11:35 AM
I can get the Elite III's for about $336 a set. My Metric dealership down the road charges $47.50
per tire, even if you take the wheel to them off the motorcycle. Bunch of new policy BS! I used
to take a tire to them off the bike, and they'd put a new one, not bought there, on for
$17.50. So anyhow, That would make my cost $431ish, just like yours. BUT, I am going
to search out someone with a tire changer in a home shop type scenario to avoid this $47.50 per
tire BS.
Herb
Edited by g1nomad 2009-08-19 12:00 PM
Posts: 550 Tacoma, WA | Wow, short miles. I got 18,000 out of my first set of dunlops. I will be going darkside for my next rear tire, however. It costs me quite a bit less to get my tires changed when I take the wheels off the bike myself, which is really not all that hard to do. It is harder putting them back on, than taking them off. I did notice that on this bike, both tires wore out at the same time. Really odd, as my other bikes were almost 2 rear tires per 1 front. I may buy a tire changing rig so I can just do my own at home, and avoid the dealer costs, and use dynabeads to balance. I have them in the rear tire of my darksider RAT bike, and really like them. At speeds of over triple digits, it is still perfect, no problems, or vibes from the tire. -----Metalguy |
Posts: 8144 New Bohemia, VA | 10k is on the low end. i usually get 14 - 15,000 miles out of the rear maintianing a 41psi in both tires. front takes me around 22,000 on out side, 19,00 on the low. |
Posts: 1484 LaPorte,Tx. | I changed the front at 19.5k, I could have run another 2k, but was leaving for a trip and wanted the new tire. Replaced with a new E-3, $159 and 37.50 to install and my local motorcycle tire dealer.
The rear tires have had issues with nails and pieces of metal. I was able to repair one and ran it to 12k, but was leaving on a 5k trip last year so changed out. It would have gone 14-15k. The rear E-3 I have on now cost me $195 and 37.50 to change out. |
Posts: 271 Belding Michigan | I only have 6000 miles so far but I can see no wear on the tires yet beats the hell out of my
Wing I got 8500 on my best day with a wild front end wobble after the first 4 to 5K never could get that sucker to settle down. Reson amoung others for the change to the Vision. Archie |
| EJ, all I can think is these guys getting more than 10-11k miles out of a rear are riding it FAR beyond the wear strips. I've replaced 2 rear tires each at 10k. The front tire was below the wear marks on BOTH sides of the center hard strip on the front E3 at 15k. That is the ABSOLUTE worst mileage I've ever gotten on a bike tire in 40 years of riding.
I put an Avon Cobra AV71 on the front, and I have the Avon AV72 shipping to me as we speak. So far I love the Avon front and it is hardly showing any signs its been ridden over 5k already. Best part is no hard strip in the center. |
Posts: 600 Linwood, MI | 18k?? Wow! I got 11k out of my rear tire. Had to change it, there was absolutely no tread left.
Front tire looks good so far. |
| Guys as you approach 15k miles I would make a friendly recommendation that you look not at the center or outer sections of your front tire, BUT rather look at the 1" to both the right and left of that hard 1" center strip where the wear bars are located. I think that you'll find you are down to the wear bars and due for a new tire since this area is the area most in contact with the road where it counts, curves.
You can ride them bald for all it matters to me, but I would really feel bad reading about someone going down or worse because they read the tire wear wrong and I didn't say something. I got caught out on this myself and found my front really slipping on a trip, I got lucky. I'll say nothing more on this matter as we are all grown ups here. Ride smart and safe..... T |
Posts: 520 Simi Valley, CA | I got 9000 right now and was thinking about this very subject.... they look fine, we will see what they look like at the 10k service. |
Posts: 113 East Ohio | I just hit 14000, ordered a rear tire as I will be making a 3000 mile trip in 2 weeks from Ohio to New Mexico and back, front still looks good
Go Super Steel |
Posts: 725 Reno County, KS | I have 10K on my stock tires and figure I've got another 4 to 6K left in em. It looks like these tires are averaging from 12 to 16K.
Edited by bigwill5150 2009-08-19 10:18 PM
Posts: 296 Central Florida | Must be me! most I ever got out of E3 rear was 11K. I went through 3 sets of E3s in 31K. I am on Metzlers now and plan on running this out as soon as I can get back on bike! I have a backup set in garage.....
I do NO burnouts, no spinning tires or brakes locking up.
Takes too much out of clutch, tires and driveline components. |
Posts: 725 Reno County, KS | Wait a minute! Just had a fleeting thought! I have a Street Primo and my Gal hardly gets to ride with me. I bet lack of passenger/trunk does make a dramatic difference in the rear tire wear. |
Posts: 3773 Pittsburgh, PA | i changed mt rear out at 9000. it didnt need it at 9000, i just had the time and knew i wouldnt have the time later. im still running the stock front tire. my dealer charges me $23 to mount and balance a tire if you bring them the wheel.. |
Posts: 619 Southeast Iowa | Those getting over 12K must ride fast enough to get "lift" as not to wear the thing out. I rarely ride 2 up and only get about 10K out of the rear and not much more out of the front. I check pressures every 2 weeks and run them at the correct pressures. My wife keeps up with me most of the time so I don't think I ride too hard. I may also change tires earlier than some, you only have 2 and it is the wrong place to get cheap........................... |
Posts: 354 20 miles west of Chicago. | Changed mine out at a bit over 13,00. Probably could have gotten a thousand or two more, but I was getting ready for a 3000 mile trip, some in the mountains, and ran on the "better safe than sorry" theory. Glad I did it, especially when I came to the "Pavement Ends
-Loose Gravel" signs in the rain. On my second set of Metzlers on the KP, but I got the Dunlops (Elite lll) on the Vision. Seems to me they're pretty damn good tires. |
| A simple question to all you posters. What type of road surface do you ride on? Does concrete surfaces wear the tires out faster than asphalt or the other way around? Is it cooler where the owners get better mileage per tire? |
Posts: 8144 New Bohemia, VA | RedRider, I'm on a mix of asphalt and concrete with moderate tempatures, 30's winter - 80-90's summer, here in Va. I get the same mileage on my 900lb bike and radial dunlop E3's as I did on my 750lb bike with bias Dunlop E3's. Around 22,000 on the front, and around 14,000 - 15,000 miles on the rear, pushing it. |
| I'm riding on most of the same roads as varyder.
My rear tire was toast @ 13750, finally changed it last night @ 13872, back to like new machine riding!  |
Posts: 550 Tacoma, WA | I am on about the same roads as varyrider as well. I was not into the wear bars when i swapped onto new E-3's. Close, tho!------Metalguy |
Posts: 8144 New Bohemia, VA | wrr1home - 2009-08-22 9:37 AM
I'm a slacker Bill, I wait until someone says, "Hey, looks like you need new tires...."
to me that is great mileage for an E3 because it is around 13,000 that I start watching them closer... |
| I'd sure like to see some closeup picures of these 12k and over rear tires folks are running.
bigwill, yes passenger/trunk do make a difference in the tire wear on big baggers but not much. From prior "model" experiences I'd guess about no more than 1k difference orat least thats what my HD's would run without the tourpack and/or passenger.
Roads here are no different than those previously mentioned and I ride all over the USA on the bike. I could have done probably 12 on the last rear but replaced at 10 as it was starting to feather (lower front higher rear tread wear). |
Posts: 1484 LaPorte,Tx. | Tire Pictures
Top picture is rear, bottom is front. Not down to the wear indicators yet, guess the mileage.
Edited by VisionTex 2009-08-23 4:03 PM
 (100_1000.JPG)
 (100_1009.JPG)
Posts: 222 Barefoot Bay, FL United States | I just rolled 8100+ miles, and the front tire looks like a Farmall front tractor tire, with the middle part very high compared to the sides. Rides like crap, Like I'm on marbles, especially over 65 and in the rain over 45. They are the original Dunlop E3's. Will be replacing very soon. Surprised at Dunlop for their "NO RECALL" policy. These could kill someone.
Doesn't everyone know, chrome is "Faster". |
Posts: 8144 New Bohemia, VA | VT - it looks like mine at around 11,000 miles |
Posts: 8144 New Bohemia, VA | double post: Okay
I think my wife is cheating on me.
So lately my wife has been working a lot of late shifts and the past couple of months she's been carpooling with a male co-worker. At first I didn't mind as it saves gas and in case she has car trouble or somthing like that, but it seems like they've become a little bit more than friends. You know....the phone calls that hang up, she starts wearing nice clothes to work and talking about him all the time...then abruptly stops leaving an uncomfortable silence.
If I'm out in the garage when she gets home (usually after midnight) he just drops her off and leaves, but if the lights are off in the garage and I'm in the house (they think I'm sleeping) they sit out in the car for about 20 minutes.
I asked her once what they were doing and she said, "Just talking". Whatever!
So, last night I decided to see what's really going on out there. So, I leave the garage door open and turn all the lights off. I go out in the garage and wait. In a few minuts his car pulls into my driveway and as I'm hiding behind some of my hunting stuff the headlights shine through my garage and I see something that I just can't believe.
The string, on my bow is fraying! Not real bad, but enough. How long should I let it go before I replace it?
Edited by varyder 2009-08-23 4:42 PM
| VT a shot of the rear from the side angled slightly from front to rear would have been better but my guess looking at just the top would be around 10500-11. I'd have been looking to replace it already. That front tire is well past replacement as well by a good couple thousand. I'd guess about 17-18k. |
