Posts: 576 , IA | so is this unit useable on all victorys my wifes vegas 08 and my vision 08 thanks |
| That's what he has on his website.
http://www.quickvic-usa.com/ |
| yes i read that on loyds sure would like to here from someone thats installed on 08 to fine out how it worked out |
Posts: 3773 Pittsburgh, PA | if like to hear about it as well! |
Posts: 293 Arkansas | Eye kant reed these stough... |
Posts: 849 , FL United States | I have one ordered and will post my thoughts of installation and any effects it has on decel popping when it comes. |
Posts: 8144 New Bohemia, VA | luke is your popping exhaust or intake related? Have you ever had you're header gaskets replaced? Just curious... |
Posts: 3773 Pittsburgh, PA | Anyone have some updates on this? id really like to hear about how this works.. it would be nice to get the Popping to stop |
Posts: 537 , FL United States | I'd like to hear as well |
Posts: 849 , FL United States | Chris, yes we checked the gaskets and tightened the head pipes to torque specs - still pops. It has been too cold to wrench on the Vis as I have to do it outside and the highs have only been in the mid 50's lately.
will post when installed |
Posts: 3773 Pittsburgh, PA | you southern guys are spoiled... 50s tooo cold?! try waking up to 8F with a high of 21F.. if it was 50 here id be on the scooter.. lol (tease'n) but i would be on the scooter.. 50 here after or during winter is a heat wave.. lol |
Posts: 3773 Pittsburgh, PA | any updates on this yet? |
Posts: 849 , FL United States | Arkainzeye - 2010-03-09 8:30 PM
Sorry,not yet installed :-( |
Posts: 537 , FL United States | HMM |
Posts: 3773 Pittsburgh, PA | Im still waiting to hear about this product and how its working for the people that bought it.. i took my vision out of the winter slumber this week, only got to ride it about 60 miles.. I was quickly reminded about the popping between gears (not always) and the slight backfire of fart through the intake.. |
I've got a nice 6 page article I wrote last month about this whole issue, I'm (for the first time) waiting for my proof reader to send it back for corrections. Nothing like throwing you under the bus sir proof reader. LOL |
Posts: 184 Allen Park, MI | Order arrived from Lloydz (as well as new gaskets) will try to get to it this weekend...lots on the to do list. CJ steering box and shaft is in front of the line.
Edited by Prostreet1 2010-03-12 7:10 PM
Posts: 354 20 miles west of Chicago. | I installed mine last week and got a 20 mile ride in today. Popping was greatly reduced, but not entirely gone. The popping that is left seemed to be almost exclusively between upshifts, particularly 2-3 and 3-4th gear, at throttle roll-off; virtually none upon deceleration. Throttle response and drivability were much improved. I set it so that after a cold start the engine idles at about 1200 RPM. After about 5-8 minutes, when the engine warms up, the idle drops to the requisite 1000RPM. After I set the IAV I reset the "popping stopper"' (green-blue) leds on the VFClll to 7. I may go to 7.5 next time out. That was the only change I made to the VFClll settings; the rest I left where Lloyd set them after the cam install/dyno tune he did last September. I had the header gaskets changed to the older, softer woven metal ones the last time it was in for service, and had the one slight exhaust leak the wrench found taken care of, so I'm reasonably sure the popping is due to the IAC and fuel map. (S1L1). At this point I feel that the popping can be minimized but not entirely gotten rid of without major changes to the configuration of the bike, particularly a new S1L1 fuel map from Victory. I'm looking foreward to Lloyd's monograph on the subject. If anybody can analyze the problem it is he. As I said, the IAV made a significant difference in the popping level and the drivability and throttle response, and I feel it was more than worth the investment.
Edited by Mudge 2010-03-12 9:06 PM
Posts: 1484 LaPorte,Tx. | I've had mine on for about two weeks now, with over a 1000 miles on it. I've made no adjustments from what Lloyd set when at Daytona. Prior to Daytona I fixed the exhaust leak on the cross over pipe at the left elbow joint. Also, I don't see any exhaust leakage at the heads.
So, with that, the POP is greatly reduced. There is no poping on deceleration and the only way I can make it pop is on shifts below 2500 rpm and at that the pops are very few. I may try adjusting a little but for right now I'm very satified with the results. |
Posts: 3773 Pittsburgh, PA | I was wondering if someone can asnwer this? What exactly is the job of the IAV? i read where people disable and purchase the Lloydz product to cut down on popping and backfiring. Does it do anything else? On start up does it enrichen the mixture?
ALSO does anyone know how to Disable the IAV? i wanna try this.. |
Posts: 1117 Northeast Ohio | Arkainzeye, the IAV limits the amount of vacuum the IAC gets, thus eliminating the pops. Most believe the reason for pops, including myself, is related to the IAC causing an intake leak. That is the simplest explanation. |
Posts: 1117 Northeast Ohio | I should have also said that the valve is inline to the IAC main vacuum hose and is a static device. |
Posts: 3773 Pittsburgh, PA | if you were to mess with the IAV hoses which one would you touch.. im confused. is there any hose that feeds fresh Air into the exhaust to burn the Unburnt gases? thats the one(s) i would like to disable.. if possible. |
Posts: 28 Reston, Virginia | I love this site because I learn so much from you guys. After experiencing the backfiring issue and then investigating potential fixes, I chose to make TWO mods to solve the problem...both mods from Lloyds.
First, I replaced the standard air intake plate with Lloyds modified intake plate. This lets the air flow smoother above the intake valves. I noticed an immediate power boost in the power curve however there is more feedback from the intake valves due to the filtered openings in the plate which sit right above the intake valves. I like the new sound. You can hear the big V-Twins sucking in massive gulps of air.
Next, I installed Lloyds intake air valve (IAV) to control the air intake bypassing the IAC. Arkainseye, I dont believe you want to disable that hose but rather control the amount of air flow inbound. It is the hose in the middle of the three. The outer ones are for air idle. The IAV once installed does the trick nicely on reducing backfiring. It takes a bit of tweaking to get the mix right but once it's set it works great. I have it idling a bit lower than before (right around 1000 rpm) but very little backfiring occurs after the install with that setting. I also notices a slight gain in MPG after the IAV install. Marking the head of the screw (I used a permanent marker) allows me to fine tune things if I need to adjust it in the future.
What I dont know is whether it is the new intake plate or the IAV which is doing the trick. All I know is that it works. Both are easy to install using the pictures from this forum. The instructions are thorough but I work better from pictures. Thanks to all for posting the pics. Thanks to Lloyd for making the tools.
Posts: 71 B'ham, Al. | I know you're asking about an '08 model but thought I'd add my 2 cents worth anyway. Put this device on my 2010 XC. Works well. But what I wanted to add is that it is very sensitive to changes. Often a mere 1/8th of a turn will make a huge difference! RR |
Posts: 432 Gettysburg, 2008 Tour Premium | Mudge, The green/blue on later model VFC is only for enriching when using nitrous. I believe the older units (like mine) did talk about decel enrichment but from what I understand they are best left set at 0. The problem with the Vision is the settings can be very far off and it will still run. I have played hell getting the VFC set after building a stepped baffle for my L2 mufflers that I was never happy with. Follow the instructions for setting the IAC, you may need to adjust the Green or idle/cruise setting on the IAC. Turn in to stumble and out just far enought to restore 1100 rpm cold idle. You do not have thaqt much time. I would leave the accel and main fuel tip in points set at the regular settings for S1L1 with intake plate. The next most inmoptant setting for mw was the accel fuel and on my bike I needed to to drop it down from 4-4.5 to 3. Until I did that the bike actuall wanted the IAC out 1/2 to 1 turn out because I was rich on accell. Setting the accel fuel correctly the bike has a nice crisp response. If you have any question about the green/blue call Lloyd--until the set at 0. |
