2010 GPS Wire Schematic
John R
Posted 2010-04-08 2:05 PM (#56986)
Subject: 2010 GPS Wire Schematic
Seams they have changed the wiring for the GPS on teh '10. Its now a 5 pin connector, and diff. colors. Anyone have the page from a manual that tels which wire is for what? ANd or the type of connector now used. Its not the 7 pin AMP that was mentioned on another htread
Man314
Posted 2010-04-10 7:18 AM (#57148 - in reply to #56986)
Subject: Re: 2010 GPS Wire Schematic
John R,
I think you sent me a PM, but I can't find it now . . . anyhow, mine is a 2009, not a 2010. I do have a wiring diagram that one of the other members on the board sent me, but it only refers to 4 wires on the 2009 and that's what I hooked up to get everything going. I can sent it to you if you want, but I think they changed the wiring between those years and I don't want to create more confusion. BTW, I found it easier to just cut the plug off of the bike and solder on different connectors that you can get at walmart. I did try the Tyco mini amp connectors like the OEM's use but the pins and plugs were soooooo small and delicate that I went the walmart route. But you will need the 2010 wiring schematic. Good luck!
