| I installed the Zumo 660 on my 09 Vision. I wired it in by soldering in new connectors to the Zumo mount and Victory wiring connection. The Zumo works like a charm. The problem is now my high/low beam, heated grips and cruise control don't work. I'm fairly sure I put all connections back in original locations. The 20A headlight fuse checks out as being good. I'm in over my head here. Any suggestions? |
| All is now working except the cruise control. The light at the on off switch comes on but nothing on the dash display and cruise does not engage. The brake light appears to be functioning fine. |
Posts: 3773 Pittsburgh, PA | I was wondering if disconnecting the battery for a short period of time would reset something.. just a thought |
| Cruise started working. Not sure how or why. All is good. |
