Posts: 156 dinwiddie, va | I did an LED install on a vision on saturday for the saddlebags. I figured some would like to see. Where the trunk plug is, I tapped into the blue/ pink wire for the trunk light. It has power even when bike is off. Ran a power wire from that to a switch mounted in the saddlebag, you can see in pic to far right. I used flexible LED's in top of saddlebag.
 (DSCN0237.JPG)
 (DSCN0238.JPG)
Posts: 492 Indianapolis, IN | Nice addition! Sounds easy also. |
Posts: 184 Allen Park, MI | Great idea.... |
Posts: 3006 San Antonio, TX | Very Nice..... |
Posts: 669 Peachtree City, GA | I like it - very nice...
The Ness Bag Liners installation looks good too. |
Posts: 1158 Richmond, Virginia | Nightvision I need to run the bike to you so you can get mine done. Will be good to know that you can also change a light bulb when needed. |
Posts: 156 dinwiddie, va | Or start your car in the morning! |
Posts: 1158 Richmond, Virginia | I can start my truck from 50 yards away................ unfortunately thats not the size of my garage.......... ( My next dream home will have a
4 car garage extra deep with lift doors on both sides. The interior of the house will be done in all concrete and tile with a center drain in each room, so instead of vacuuming, dusting, mopping, and sweeping, i can just hose each room down when it gets dirty......... |
Posts: 156 dinwiddie, va | wow! too much info! |
