Posts: 575 Spirit Lake IA "Birthplace of Victory Motorcycles" | I'm replacing my front amber turn signal lamps with clears. In checking the service manual, it says that you need to remove RH and LH leg fairings. Has anyone done this without removing these?
Posts: 8144 New Bohemia, VA | you can undo enough at the top and pull back to remove as there is enough flex, but that's a little unorthodox. | |
