Gear Indicator question
g1nomad
Posted 2010-09-15 9:47 AM (#69587)
Subject: Gear Indicator question
SC, Bluffton
Maybe I have missed it in the posts, but I was curious as to a fix for the Gear Indicator.
My Vision, which has been pretty darn good on problems, has always had an issue with deciding whether it is in first or second. Even after freshly changed oil, which I think I read in other posts helps.
The other day, I was cruising steady at around 60 MPH. The indicator kept switching between 5th & 6th while cruising in 5th.
I do not have a local dealership, so it isn't something I will have looked at anytime soon. I was just curious what the fix is, and if one could do it theirself without tearing too much apart.
Thanks.
Herb
johnedoe
Posted 2010-09-15 9:58 AM (#69589 - in reply to #69587)
Subject: Re: Gear Indicator question
North East Oregon
Likely a bad sending unit...... Mine got to a point that it would no longer indicate 6th gear..... took it to my dealer they rep,ace the sending unit under warrenty..... all is good now.
Bearcat
Posted 2010-09-15 5:21 PM (#69605 - in reply to #69587)
Prescott Valley, AZ
Mine would not indicate 6th gear a few months after I bought it. Dealer replaced the sending unit and 25,000 miles later it is fine.
Flatsix
Posted 2010-09-15 9:33 PM (#69621 - in reply to #69605)
Fargo, ND
Anyone know the cost of the sending unit & labor...as some of us are off warranty?
nohawg
Posted 2010-09-15 10:36 PM (#69628 - in reply to #69587)
Fargo, ND
If it's just the different bolts and washer that fixes it and not the sending unit itself, it would run you about $165 to $185 including the side cover gasket that needs to be replaced when it's done. I don't know the cost of the sending unit itself. For mine (bolt fix), the parts were less than $40 of the total. I imagine the labor to change the sending unit should be about the same as this fix but I'm no mechanic so just my opinion. I only know the price because the dealer asked if I was willing to pay to fix it if the extended warranty didn't cover it. Luckily it did, so no charge to me.
Joker
Posted 2010-09-16 8:12 PM (#69688 - in reply to #69587)
Buford, GA United States
I have never had a problem with mine and if it messes up after reading this I am not going to be happy....I am just now getting my mirrors to stop vibrating since I read about that problem!!! Damn trunk is starting to rattle again too...
