Posts: 27 New York City | You all may already know this but discovered something today. As I live in NYC I do not have a hose or driveway to clean the bike. New Ness Vision and needed cleaning. I am riding south to Florida and stopped to visit friends in Atlanta. They have a driveway and hose.
Have seen a Vision on tipover protection noted for cleaning and I really needed to get to the wheels to clean and polish the billet wheels. Leaned it over to left (slightly uphill on driveway) and it was great way to get to the wheels and was able to thoroughly clean and apply polish.
Leaned it over to the right, slightly downhill, and got ready to clean. Quickly smelled gasoline and saw what looked like a sheen of gasoline sliding down over the brake pedal area. Immediatly lifted up and hosed it off. It was then that I realized that I had 3/4 tank of gas and it had transfered to the right tank and applied upward pressure to the gas cap, which while securely on is likely not designed to take that upward pressure.
Hosed it off carefully and started it up to move it around (with friend standing by with a fire extinguisher) and it started up fine, seemed to run with no problem though I did not take it far. Tomorrow I ride out for Florida so:
Am I right to assume that the cap was not designed for upward pressure and i need to be sure to have less than a quarter tank next time I try this?
Is there anyting else I need to check on the bike at this point?
Is there a problem with my gas cap?
Now I need to find another way to wash and polish the wheels. Detailer here I come!
Thanks...
bpilgrim |
Posts: 742 North Orange County CA | A "new and improved" gas cap design was implemented after 2008 model year. I don't know if it will help keep gas in the tank while its laying on its side. Soft tank filler necks were becoming deformed and leaking.
And so it goes........................
Regards to Montana and Elliot.
Posts: 492 Indianapolis, IN | BP, Just another way to approach general cleaning of your bike. I have never hosed my bike off since new. Don't like getting water in the delicate places on the bike under pressure, that's just me. But considering you don't have the luxury of a hose and space to wash, consider my method. Buy a nice supply of micro fiber cloths at the local department store or auto parts store, they last a long time if you keep them clean. Start with the windshield so that you are washing it with a new clean cloth. Wipe a moderate area clean, turning the cloth often and then immediately dry with a second cloth. Rinse often in a bucket of plain hot water and then rinse the cloth again in a second bucket to get as much dirt out of the cloth as possible. Continue in this way working from the top to the bottom (cleanest part of the bike first finishing with the dirtiest). The key being to keep the cloth rinsed often. When you are done the bike will be clean as new and it will take you less than 30 minutes. I like to use a little spray "Wax-As-You-Dry" type wax every once in a while while doing the dry off step to help protect the finish. I usually end up using 4 to 6 cloths each time I clean and just throw them in with my whites when I do my laundry. Depending on how dirty the bike gets I do one of these cleanings about once or twice a week. I still get comments that the bike looks like I just rolled it out of the show room. (15500 miles) I know this sounds like a pain but believe me once you get used to the routine it just seems like a few minutes and a sparkling bike once again. As a matter of fact for those that try to dry their bikes after the traditional hose bath, I would be willing to bet I could clean my entire bike, dried spotless in less time than they spend just drying the bike off. Oh and I have never laid the bike over for cleaning, don't seem to need to. Just my alternative way to keep her looking new. Take it or leave it. |
Posts: 27 New York City | To tarpits: you are obviously a well read person, and I appreciated the allusions. To others: read more Vonnegut!
To Hoosier: Interesting idea. I may give that a try. Sounds like it would work. Haven't figured out how I clean and polish the billet wheels. I could barely reach them when the bike was on the tipover protections, could not imagin how to reach them when upright. How can you reach the whole wheel?
We would like the night canopy now.
Thanks...
bpilgrim |
Posts: 8144 New Bohemia, VA | a good motorcycle jack can give you enough lift to clean the wheels, probably better than on the tip overs. |
Posts: 492 Indianapolis, IN | varyder - 2010-10-05 6:34 AM a good motorcycle jack can give you enough lift to clean the wheels, probably better than on the tip overs. Agreed. This would be my solution as well, although I didn't have a lift until just a few days ago. With the lift you can clean the wheels in less than 5 minutes each. Without it does take more effort. Our buddy in NYC my not have that option so he may just have to do the "rub and roll" method on the wheels, takes more time but if you clean often it really doesn't take much effort. If you can get a lift do it. Again this may not be everyones method of choice, it's just one that doesn't require a garden hose, 200 gallons of water, soap, sponges, a blow dryer and extension cord to get the bike clean. Two buckets of very hot water, 6 cloths and some spray wax if you like is all it takes. End result is spotless clean and no spray from the nooks and crannies the first time time you ride after a wash job. ;-) |
Posts: 741 Central New York | If gas is coming out there is a problem with either the gas cap or filler neck. I would try a new cap and if it still leaks when leaned over someone has trashed the neck. Doesn't take much, a heavy hand with the fill nozzle will do it. |
Posts: 1484 LaPorte,Tx. | Don't know about our area in NYC, but where I'm from there are many places that do bike detailing for a living. You may want to take your bike to them if it is really dirty, they would have all the tools to completely do a detail on the bike. Normally not too expensive. In between, use the microfiber towel and a spray detailer and you should be able to keep the bike nice. |
