| Where did you put your shock pump?
I picked up a pump for a bicycle and it works great, plus I found a great place to put it.
It only cost $30 shipped, and it is smaller than the Victory or HD models.
http://www.topeak.com/products/Mini-Pumps/PocketShockDXG
The gauge range dosen't work great, but I'm using the factory supplied gauge. I also found a great place for that too.
 (PocketShockDXG.jpg)
 (SNC00042.jpg)
 (SNC00043.jpg)
 (SNC00044.jpg)
Posts: 3006 San Antonio, TX | That looks great. Nice mod.
Ride Safe! |
Posts: 1117 Northeast Ohio | What kind of velcro is that? Double sided? |
Posts: 8144 New Bohemia, VA | you done good! |
| ScoreBo - 2010-11-14 12:55 AM
Single sided, homemade double sided, pain in the butt. Wasted a couple of pieces in the process. No velcro for the air gauge, instead I used a cabinet door closer. I need to paint it black when I get a chance. |
Posts: 3773 Pittsburgh, PA | i put mine in the spot where they CD player is to go. i put alot of stuff down there. |
| Arkainzeye - 2010-11-14 4:24 PM
My tools are in that spot, and it is a pain to get stuff in and out of there. Hence why my tools are in there - they don't get used that often.
The pump and gauge are used often enough to justify a better location. |
Posts: 1484 LaPorte,Tx. | I've never seen the CD player mounted under the trunk. Everyone I've seen it is mounted in the trunk. Under the trunk is a good place for tools or other stuff, but it is not a sealed area, so moisture can get in there. |
| VisionTex - 2010-11-15 10:40 AM
Didn't know that, but then again I never rifled around someone elses trunk, nor did I have a desire to own the changer. |
Posts: 162 Northern NJ | VisionTex - 2010-11-15 11:40 AM
I store stuff there in a clear Ziplock bag. |
Posts: 74 Lehigh Valley, Pa | I store my pump in the top of the left side saddlebag as I hope you can see in the picture. A small bungee cord holds it tightly in place and it is completely out of the way in what is really unused dead space.
 (Pump.JPG)
Posts: 8144 New Bohemia, VA | I felt that was a good place for a while, but the way I ride it gets pretty nasty in that area so I just keep it in the bag now. I am thinking on the trunk method though. |
Posts: 804 Perry Hall, MD | The trunk lid idea is really good.
I use the CD cavity for some cleaning supplies, but recently saw a small car safe at Lowes that looks like it could be mounted in there to hold a handgun or other essentials. I would also highly recommend getting the saddlebag lid organizers. For just a couple of bucks and an hour or two to install they are great. Hold a windbreaker, first aid kit, emergency space blanket, air pressure gauge, extra tie downs, maps, and more without taking space away from the bags themselves. |
| VRat - 2010-11-15 1:08 PM
Thought about that location too, but the biggest issue with the pump getting wet isn't an issue with the pump.
The big issue is water getting into the pump means you can get water into the shock, and that is a big problem that can screw up the shock. All air shocks do not do well when they get water in them, and all MFG's warn you about it - including Victory.
Edited by sgiacci 2010-11-15 8:40 PM
Posts: 74 Lehigh Valley, Pa | I've ridden in some pretty wet weather and never had an issue with water getting "into" the pump. By the way they pump unscrews and comes apart in about 10 seconds if it needs to be cleaned. As they age a little light oil helps keep them performing like new.
I also went a looked at the way the pump is sitting in the bike, water is not going to get into the pump unless I am running the bike backwards in a monsoon.
Edited by VRat 2010-11-16 7:57 AM
| VRat - 2010-11-16 7:52 AM
We need a better picture. Where is the gauge head? |
Posts: 3006 San Antonio, TX | FYI,
The area under the trunk is for the CB Radio. The CD Player option mounted inside the Trunk.
Ride Safe |
Posts: 277 Apopka, FL | Genius mounting. Need to utilize all space. |
Posts: 849 , FL United States | K2V2 - 2010-11-15 1:20 PM
+1 |
