Posts: 104 Corona, CA | The Road Star I had was a great bike for cruising. One of the popular mods for it was to change out the front drive sprocket from a 33 tooth to a 31 tooth.
Wow ! That made the bike a rocket through the gears ! You gave up a little on the top gear but it was hardly noticeable.
Has anyone changed out the Visions front sprocket to gain more lower end performance ? With the 6th gear OD it seems like this would be a great way to get some real low end grunt and make the gears feel a little more close in the apparent ratio.
It's raining. Idle minds . . . |
