Posts: 28 Mesa, AZ United States | Just changed the oil in my 08 Vision. Paid $15 for a filter from the dealer. Haven't had time to check at the local auto parts but I am assuming there is a much cheaper oil filter available that will work. Anyone have any info on what brand and part number will work on a vision? |
Posts: 66 Oklahoma City | check here: http://www.vision-riders.com/bb/forums/thread-view.asp?tid=1990&pos... |
Posts: 28 Mesa, AZ United States | Thanks very much. |
Posts: 1359 New Bohemia, Va | Super Tech 7317 walmart $2.87 |
Posts: 66 Oklahoma City | Cap'n Nemo - 2011-06-19 3:05 PM
That is the filter I used for my Kingpin, and the one I'll use for the Vision as well. |
Posts: 492 Indianapolis, IN | <p>The victory vision uses the same oil filter as an 05 honda civic. If you look up honda civic filters it will provide you with a cross reference match for the vision. I use the wix 51356. It is available at OReily Auto Parts for about 8.00. Wix is one of the highest quality filters made. At the following web site you can buy them by the case of 12 for about 52.00. Add in shipping to Indiana and that's about $5.20 each. Not bad for a high end filter. www.discountfleetsupply.com/wix51356.html</p>
Edited by hoosiervic 2011-06-19 4:21 PM
| I use the Napa gold filter for about 5 bucks.
Posts: 411 Dallas, Texas | Purolator PL14610...Amazon has them for about $6...IMHO, hands down the best |
| partial to the Bosch 3323 its 12.00 but i like it |
Posts: 3773 Pittsburgh, PA | there are sooooooooo many choices for oil filters for our visions. i stopped using oem due to the price, and they arent anything special. i cut one open just to see.. right now i am using a mobil1 oil filter. i got it onsale with mobil1 cycle oil from pepboys. |
Posts: 412 Fargo, ND |
Cap'n Nemo nailed it...do what he says!
Posts: 79 Memphis,Tn. | Buy the Victory filter and three or four automotive filters that will fit. Cut them all open and see what's inside.
I examined several filters before my first oil change, including my personal favorite Mobil1 brand.
Seeing is believing. I've used the OEM Victory filter exclusively ever since.
Posts: 492 Indianapolis, IN | TopFuel - 2011-06-20 11:48 PM Buy the Victory filter and three or four automotive filters that will fit. Cut them all open and see what's inside. I examined several filters before my first oil change, including my personal favorite Mobil1 brand. Seeing is believing. I've used the OEM Victory filter exclusively ever since. That's what I did and that is why I use the Wix filter. When disassembled you can not distinguish any difference between a wix and an oem vic filter. The materials are the same, and even the markings on the components are the same. Since victory doesn't manufacture any filter I would bet money that they are being manufactured by wix under contract with the vic logo printed on the outside. I'd rather pay 6 bucks than 15 for the same item.
Edited by hoosiervic 2011-06-21 7:28 AM
| Wix does make the factory oil filter. And as far as I can tell they're the same filter. |
Posts: 1359 New Bohemia, Va | I've used the supertech 7317 filter for most of my oil changes with no ill effect. Changing the oil anywhere from 3,000 miles to 6,000 miles I've probably used at least 10 of them. It does NOT burn or use oil, though I do have that stinkin' oil sensor leak that I have so far put off changing. I guess I can do it under warranty. You all quit worrying so much with the details and get out and ride until the wheels fall off...
Edited by Cap'n Nemo 2011-06-21 9:29 AM
Posts: 3773 Pittsburgh, PA | yeah those wix filters are top grade. i like how my napa always has them in stock.. this time i went with a mobil1 oil filter and mobil1 motorcycle oil it was a package deal.. |
| Cap'n Nemo - 2011-06-21 9:01 AM
I've used the supertech 7317 filter for most of my oil changes with no ill effect. Changing the oil anywhere from 3,000 miles to 6,000 miles I've probably used at least 10 of them. It does burn or use oil, though I do have that stinkin' oil sensor leak that I have so far put off changing. I guess I can do it under warranty. You all quit worrying so much with the details and get out and ride until the wheels fall off...
Lol this I agree with this. I use Napa gold because Wix makes them and the the local Napa store owner is a friend.  |
Posts: 3006 San Antonio, TX | Cap'n Nemo - 2011-06-21 9:01 AM
Please change the oil pressure sensor if it is leaking. The oil can fly back on the rear brake when you are riding. Oil is never a good thing to have on the pads plus it makes a real mess out of the rear tire and engine.
The oil pressure sensor/switch it by far the easiest part to replace on the Freedom 106.
Ride Safe |
Posts: 1359 New Bohemia, Va | radioteacher - 2011-06-21 9:47 AM
Ride Safe
So true, so true. But there really no oil flying, it's one of those annoying seeps that collect the dust and I don't ever think about it between times. I might hit it up and get it fixed under warranty to my next trip to a dealer, provided I pre-arrange it.
I've found no evidence of it ever getting on my brakes, but I do agree with you RT. |
Posts: 130 Houston, Tx | I actually purchased the lifetime K&P filter from Conquest and used it on my previous bike ('08 Jackpot). Before trading it in, I changed oil and threw on a cheap ass filter. Then.. at first oil change on the Vision tossed on the K&P - worked like a charm as all Vics use the same size. I paid the price early on and now never have to buy another. I also have the magnetic plug... so for every change all I need to do is make sure I have a good crush washer (can be bought from dealer) and the oil (also purchased at dealer in 5Qt container for less then $40 with local chapter discount). Works for me....
Posts: 79 Memphis,Tn. | Looks like a Wix 51356 should fit. I'll pick one up and cut it open. Thanks.
Posts: 3006 San Antonio, TX | Oil pressure switch: I had the dealer order one under warranty and one more to leave in the vision. All I need to replace it is an adjustable wrench and a rag to clean up the mess. When they came in I did the work myself.
Ride Safe |
Posts: 3773 Pittsburgh, PA | Im not sure if this was talked about yet or not. if it was then im sorry for the repost.. but i know alot of people use the napa gold oil filter (made by wix) well today i went to my napa dealer to get some amsoil and i had him look up my oil filter for my vic to see what they had in stock. then he goes to see if he had it in stock and comes back with 2 oil filters... i told him i only needed 1... he said i wanted to show you this NEW oil filter... he had the napa gold in his hand along side the New Napa Platinum oil filter. the part number for the napa gold was (51356) and the napa Platinum is (41356) i took both of them out of the box and you can honestly feel the Platinum one was heavier...
http://www.youtube.com/watch?v=NRbDfhgOOgo
http://www.nfvmc.com/platinumnapafilter |
Posts: 8144 New Bohemia, VA | I'm heavier, but that don't mean I'm better. |
Posts: 3773 Pittsburgh, PA | varyder - 2012-01-24 2:49 PM
it would be if you were trying to hold someone down... |
Posts: 8144 New Bohemia, VA | I had a bucking teenage son, it came in handy a few times ----- he's in the infantry now, but he still calls me sir. |
Posts: 3773 Pittsburgh, PA | varyder - 2012-01-24 3:24 PM
Nice !! lol |
