Posts: 179 CARTAGENA Spain | Hello everyone, my question is: to serve these items DINOJET POWER COMMANDER, ARLEN NESS BIG SHOT FUEL FUEL EFI WISECO TUNER AND CONTROLLER. Valen all for the same need to change the exhaust to use any item thereof. I have a Victory Vision 2008 with 26,000 km and I'm from Spain
| With out cams the F/C will not do much for you. Change your exhaust. Don't spend the money on a Vic download not worth it.
If your just adding pipes you'll be fine. You'll get a popping out of the exhaust now and then. UN Hook the o2 sensors and that will take care of most of the popping.
If that bothers you go to Lloydz and by a IAV idle air valve that will get rid of all the popping.
http://www.quickvic-usa.com/store/item_view.asp?estore_itemid=10000...
If you still want a fuel control buy one from Lloydz he is the best horse power guy for your Vision |
Posts: 554 2 mi from Jim Beam n KY | Send Lloyd an email and tell him what you want to do. Follow his advice!!
www.lloydz.com
Posts: 51 Arizona | I recently had a Lloyd's fuel controller along with big intake installed, and I can say there is a huge difference in how my vision performs. Which is also an 08. Pretty good bang for the buck in my honest opinion. |
Posts: 373 Lansing, MI | LLOYDZ!!!! Did you know Ness ripped off his idea? |
Posts: 935 Rockford, IL | cook06vegas - 2011-08-16 11:41 AM LLOYDZ!!!! Did you know Ness ripped off his idea? Um...not defending Ness here. Simply clearing up potential confusion.
When it comes to the fuel controllers they didn't didn't "rip off" Lloydz or anyone else for that matter. Both Lloydz and Ness get their controllers from the same supllier.... http://www.dobeckperformance.com/ Other than the labels and packaging they are the exact same units.
Posts: 373 Lansing, MI | Well, if you don't believe me ask Lloyd about it sometime. BTW, I said "idea"...
Posts: 1632 Jasper, MO | According to Lloydz, they have their controller built by Dobeck, but with Lloydz proprietary programming, which is different than all the other brands of similar controllers built by Dobeck.
The stock exhaust works great with any of Lloydz performance improvers. No need to change the exhaust unless you just want more noise.
Edited by rdbudd 2011-08-17 11:26 AM
