Posts: 59 Austin Texas Yaaaalll | Greetings all.....New Vision owner here. I had the Sirus/XM installed at the dealer and ever since the reception has been horrible. I pulled off the plastic in front of the windshield and saw the antenna tapped on to the backside.
Is that the FM or satellite antenna? If that is the FM where do suppose they stuck the XM antenna. I need to reposition it for better reception.
Thanks in advance. |
Posts: 3773 Pittsburgh, PA | that taped on antenna on the front of the bike IS for FM.. |
Posts: 59 Austin Texas Yaaaalll | Thanks for your help.
Posts: 3204 Memphis | The XM antenna looks like a flattened cube (might even say Sirius on it) and should be mounted on the top of the dash, line of sight to the sky.
Edited by SongFan 2011-08-01 12:28 PM
Posts: 59 Austin Texas Yaaaalll | Thanks Michael....... There is no XM antenna on the dash. I have had XM before on my bikes so I know what they look like. The XM Module resides in the right saddle bag and the antenna wire (separate from the harness) runs up under the console. I guess I will have to take the dash and console apart and look for the puck antenna. The two gray harness must be 1.) XM 2.) CB or CD disc changer. The latter runs all the way to the trunk. When I find it (the puck antenna) I will run it up to the dash. Thanks again for your help. Next up....... moving my Clearwater LEDs from my BMW adventure to the Vision. |
