Posts: 231 Desert Hot Springs (Palm Springs area), CA | Ok, so I was packing my Nessy for a trip and I noticed the small "cubby" area just forward from the main right saddle bag. I know on the left side it is where the air shock filler is but on this side, what do you think Ma Vic was thinking? Here is a picture that highlights two "slots" or areas that could be used by a small door or cover. Was there any idea of a little door inside the main door?
Posts: 137 Houston, Texas | My XM Radio module is mounted in that space but doesn't correspond to the slots.....good question.
Posts: 785 Mt. Vernon, WASH. | That's where I keep a couple of small terry cloth towels and the lanyard badge holder I use for my registration and insurance card. The neck lanyrd is looped around the front hinge arm, works good, last long time- |
Posts: 337 san antonio, tx | I've been wondering the same thing. There are no corresponding notches or anything at the top. |
Posts: 181 Henlow, Bedfordshire, England | The left side bag is a mirror image but with a door and hides some suspension parts I believe. Looks like you should be able to buy this door and fit on right side but haven't tried |
Posts: 3773 Pittsburgh, PA | i roll up my gloves and put them in there. on my 2011 the left side is being used by the ABS system. |
Posts: 741 Central New York | This is outside the 'weather tight' area, correct? |
Posts: 231 Desert Hot Springs (Palm Springs area), CA | glighto11 - 2011-08-22 9:41 AM
Yes it is... It just seems that the engineers put those "slots" in there for a reason... Now, what could it be? |
Posts: 164 Quad Cities, IL | I'm not sure I agree that it is outside the "weather tight" area. Like above, my XM module is in that spot and I have never had any water issues from washing or riding...and I ride in plenty of rain. It would be intersting if there was a little door panel but I have never seen one available on-line or in a catalog. |
Posts: 231 Desert Hot Springs (Palm Springs area), CA | HLUSN8 - 2011-08-22 6:54 PM
OK, I'm going to backstep a bit here... It IS outside the main compartment that has it's own seal, BUT, it is inside the clamshell of the door that has another seal... Thanks HLUSN8 for keeping it accurate. |
Posts: 189 Baltimore, Md | I used that spot to mount my Fuzeblock for connecting extra electronic devices like my GPS, Radar Detector and MixIt Amp.
Posts: 741 Central New York | JS5Owner - 2011-08-22 9:13 PM HLUSN8 - 2011-08-22 6:54 PM I'm not sure I agree that it is outside the "weather tight" area. Like above, my XM module is in that spot and I have never had any water issues from washing or riding...and I ride in plenty of rain. It would be intersting if there was a little door panel but I have never seen one available on-line or in a catalog. OK, I'm going to backstep a bit here... It IS outside the main compartment that has it's own seal, BUT, it is inside the clamshell of the door that has another seal... Thanks HLUSN8 for keeping it accurate. If you have a second seal, one other than the one sealing the main compartment, please post some pictures, for I am surely missing some parts on my bike.
Posts: 231 Desert Hot Springs (Palm Springs area), CA | glighto11 - 2011-08-24 10:09 AM
Ok, what I'm talking about is a plastic rolled edge across the top of the opening of the bag. While it isn't rubber (at least on mine) it seems to provide a "sealing" effect of at least diverting the water to the fore / aft of the bag. Here is a pic:
Also, (back to my original question) the left bag has the same cubby with "slots." What were they thinking? Has anyone put something in the rightside cubby only to have it fall out into the bottom of the bag? It appears to have any "sealing" by the clamshell.
? Has anyone put something in the rightside cubby only to have it fall out into the bottom of the bag?? It appears to have any "sealing" by the clamshell.
When I first got it, I thought it was the perfect place for my little emergency kit (flashlight, tire puncture kit, air gauge, etc.). Problem was that I didn't have a little bag for all of it so put it all in individually. Lost the tire gauge, and played heck trying to fish the flashlight out of there during a stop. I now stuff it all in a little bag, roll it up in a handkerchief, and it stays there just fine. |
Posts: 51 Edmonton AB, Canada | First aid kit! |
