Check your crank/timing cover
Cap'n Nemo
Posted 2011-09-08 6:44 AM (#96026)
Subject: Check your crank/timing cover
New Bohemia, Va
Maybe not a big concern for most, but mine just started leaking. I've got to inspect it closer but I only saw seepage. I noticed the other day sitting at a light and I smelled engine oil burning, thinking it was a car close to me I disregarded. Yesterday I was at a light and I looked down and saw the oil discoloration on the casing around the cover. I got home and tightened the screws that hold the cover on and they took a turn so I figure that should do it. My first official leak and it started after.....
Has anyone else had issues with this cover?
Edited by Cap'n Nemo 2011-09-08 7:01 AM
Posted 2011-09-12 7:37 AM (#96320 - in reply to #96026)
Subject: Re: Check your crank/timing cover
im not expert, but i thought that cover was just that.a cover. i didnt know it was meant to be oil tight? unless it is then all should be good.
