explanation of pictures just posted on thrush mod
brucehaslam
Posted 2011-02-08 12:46 PM (#78971)
Subject: explanation of pictures just posted on thrush mod
Mesa, AZ United States
1st photo shows left side with stock muffler removed. Note the rear bracket with the hole in it to which a spacer bar will be attached. Also note the bracket just in front that I cut off with a hack saw.
2nd photo is just a close up of that rear bracket.
3rd photo is just a shot of the 1" square tubing in which I drilled the 3/8" hole ( I previously said it was a 1/2" hole. not so.
4th photo is a shot of the spacer tubing attached to the bike.
5th photo is another shot of the spacer taken from the rear to show the relationship to the exhaust pipe up front.
6th photo just shows the cuts I made in one end of the thrush so that the muffler clamp can create a good seal. (Note: make sure you don't cut them too deep)
7th photo is of the thrush attached to the exhaust pipe and shows the proximity of the muffler to the spacer bar. It just touches it.
8th photo shows how I attached the muffler to the spacer bar with two pipe clamps.
