battery cable fix for good
Posted 2010-10-18 2:15 PM (#71837)
Subject: battery cable fix for good
I stop for gas and when I went to start the bike all I got was a click. I found the cable had come loose from the battery. When I got home I checked again and fixed it for sure. I found that victory still uses solid battery cables. Not good. There are cables out there that flex cause they are made from welding cables and have a hundred times the copper wire in them that a stock cable has so more juice to where you need it.
You can go to any hardware store and but these star washers for about a 25 cent a peace. Put one on each thermal.
(IMG_0009.JPG)
Attachments IMG_0009.JPG (99KB - 6 downloads)
