h4 bulb in driving light
gary1
Posted 2012-11-04 8:12 AM (#126174)
Subject: h4 bulb in driving light
just wandering if anyone has put ahigher wattage bulb in the drivinglight my35watt hsi bulb burntout dealer was out of stock and a100 miles away put a60 55 watt h4 bulb inhad to bend little tabs out on h4 bulb seems too work just fine ill probably just turn it on for backup when on of the other bulbs burn out
Denny Pink
Posted 2012-11-04 8:24 AM (#126177 - in reply to #126174)
Subject: RE: h4 bulb in driving light
Gary 1,
One long sentence you have there! But, be careful about going up too high in wattage. Two things can happen, a blown fuse to save the wiring, but more importantly you could burn and warp your bulb reflector. Going up 20 watts means a lot more heat. Watch your bulb socket/reflector carefully, or pause your project until you can get the correct 35W replacement. Good luck!
Denny Pink
kris1956
Posted 2012-11-04 9:58 AM (#126180 - in reply to #126177)
Denny Pink - 2012-11-04 8:24 AM Gary 1, One long sentence you have there! But, be careful about going up too high in wattage. Two things can happen, a blown fuse to save the wiring, but more importantly you could burn and warp your bulb reflector. Going up 20 watts means a lot more heat. Watch your bulb socket/reflector carefully, or pause your project until you can get the correct 35W replacement. Good luck! Denny Pink
 +1
Monkeyman
Posted 2012-11-04 10:32 PM (#126212 - in reply to #126174)
Subject: Re: h4 bulb in driving light
Peru, IN
If you're talking about the cyclops light, you could always put an HID in there assuming you can find one that fits. It seems like it's not a standard H4 base or something's off on my '12.
atvtinker
Posted 2012-11-05 9:11 AM (#126222 - in reply to #126174)
Grand Cane, LA
The center HID version of the driving light is DS1S bulb. I think the socket hole is different compared to the halogen version, but am not sure. You can get the HID version from Victory or ddmtuning.com.
Monkeyman
Posted 2012-11-05 10:59 AM (#126237 - in reply to #126174)
Peru, IN
No way am I paying $500 for the kit from Victory. OEM is what looks like a standard H4 bulb.
Posted 2012-11-05 1:02 PM (#126249 - in reply to #126174)
The Halogen cyclops socket is a HS1 socket. Basically a H4 bulb without the Hi/Low. Many manufacturers make a HID bulb that fits that socket and it it a HUGE improvement over the stock halogen. I have the PIAA HID bulb in and love it! http://piaa.shptron.com/products/productdetail/part_number=PIA71190...
Amazon price $108
Monkeyman
Posted 2012-11-05 1:05 PM (#126250 - in reply to #126174)
Peru, IN
Are there any tricks to installing it? I had one from VictoryHID and just couldn't get it to fit in the hole. The flat area at the bottom seemed to be the problem.
Posted 2012-11-05 6:13 PM (#126259 - in reply to #126174)
how about this
http://www.ddmtuning.com/Products/DDM-35W-55W-Dual-Motorcycle-HID-K...
http://www.victoryhid.com/hid-VISION.php
Posted 2012-11-05 6:57 PM (#126264 - in reply to #126174)
The PIAA is designed for the HS1 socket, no mod needed. It also has a directional shield so the light will not bounce up at oncoming traffic.
Monkeyman
Posted 2012-11-06 1:08 AM (#126276 - in reply to #126174)
Peru, IN
I had the one from VictoryHID. It just wouldn't fit (or I was messed up somewhere). It had a shield, too. And it was only $50. Not sure about over $100. Thanks.
