Toe pegs!!
Plumley
Posted 2009-06-26 10:13 AM (#37584)
Subject: Toe pegs!!
Alberta, Canada
I bought some new pegs for my toe shifter and the brake peddle and am having issues with getting the stock ones off!!! Does one just cut the rubber off???? I would appreciate any advice! Happy riding.
Blackjack
Posted 2009-06-26 10:48 AM (#37586 - in reply to #37584)
Subject: RE: Toe pegs!!
Cottage Grove, Mn
Plumley - 2009-06-26 9:13 AM
No, use a vise grips
nohawg
Posted 2009-06-26 11:36 AM (#37590 - in reply to #37584)
Subject: Re: Toe pegs!!
Fargo, ND
Actually, get a bottle of the squirt hand soap, the liquid type that turns to foam. Spray a little at the ends of the rubber and let it soak underneath, then twist the rubber. As soon as it breaks loose, it will come right off with a bit of twisting and pulling.
Posted 2009-06-26 11:53 AM (#37591 - in reply to #37590)
Grunt!
Lotzafun
Posted 2009-06-26 12:15 PM (#37592 - in reply to #37584)
Rockford, IL
Two choices:::
1) Fight them for a while and hope you don't pass out from exhaustion prior to them coming off.
2) Cut them off and toss in the garbage.
Travelin Man
Posted 2009-06-26 7:03 PM (#37609 - in reply to #37584)
If you are replacing the pegs with the Kury Akyn extended pegs the simple way to get them off is to use a Vise-Grip and twist counter clockwise as the screw is bonded into the rubber and you won't be need the screw as the K-A pegs come with a replacement screw. I did this change out and the K-A pegs are about 1" longer than the stockers and look much better.
Shyster
Posted 2009-06-26 8:55 PM (#37614 - in reply to #37584)
Do you have a link for the ones you bought?
 ~Shy
nohawg
Posted 2009-06-26 11:02 PM (#37622 - in reply to #37584)
Fargo, ND
Sorry, I misunderstood exactly what you were trying to do. Go with the visegrips!
Travelin Man
Posted 2009-06-27 9:24 PM (#37643 - in reply to #37584)
I got the ones with 4 bands on them which are the long ones.
http://www.kuryakyn.com/index.cfm/go/Home.ProductDetail/catID/18/sc...
witchbiker
Posted 2009-06-27 11:17 PM (#37652 - in reply to #37643)
Did you click on Harley, Metric, or Gold Wing? Victory ain't there!!
Big Vic
Posted 2009-06-28 5:13 AM (#37655 - in reply to #37584)
Southeast Iowa
You can buy the 4 band Kurakyn from Victory part #2875019 they list for $19.99 ea. You can also buy the Ness Diamond band shift peg #2875166 which list for $49.99
