Middle brake light mod question
Rakk17
Posted 2010-04-14 10:36 AM (#57462)
Subject: Middle brake light mod question
Have te bike ready to do the middle brake light mod and I was curious how to push out the pins rather than cut. Anyone have pictures or a video of it? I tried doing a search but I may have missed it.
Also there is a pair of wires with a grey connector hanging free under the seat. Looks like its coming from the radio area. What is that?
hoosiervic
Posted 2010-04-14 12:24 PM (#57472 - in reply to #57462)
Subject: Re: Middle brake light mod question
Indianapolis, IN
The plug under the seat is the supply for an optional 12volt plug used for passenger heated gear. There is also one under the cover in front of the seat for the rider's heated gear plug. BTW these plugs can be used for any 12v accessory you may want to control on and off with the ignition switch.
charbin
Posted 2010-04-14 2:33 PM (#57483 - in reply to #57472)
Lavon, TX
The rear plug is battery constant 12V (same as the one in the trunk, if you have a tour); the front plug is ignition switched 12V (same as the one in the glovebox).
I plug my battery tender into the rear plug (using cigarette to powerlet adapter).
NOTE: if you ever feel adventuresome and want to implement my Sequential Blinkers mod (listed in Vision Tech Ref), you will need these two wires reconnected in order to get turn signal override (of brake signal) on the active signalling side.  So, try to carefully remove them rather than cut them.
Rakk17
Posted 2010-04-14 2:59 PM (#57487 - in reply to #57483)
charbin - 2010-04-14 12:33 PM
NOTE: if you ever feel adventuresome and want to implement my Sequential Blinkers mod (listed in Vision Tech Ref), you will need these two wires reconnected in order to get turn signal override (of brake signal) on the active signalling side.? So, try to carefully remove them rather than cut them.
I would prefer to remove them rather than cut but I'm not sure how to do it.
victoryvisiontour
Posted 2010-04-14 3:55 PM (#57489 - in reply to #57462)
There is a special tool to remove the pins. It would not be worth buying for one job. I have been succesful with a small pick.
glighto11
Posted 2010-04-14 4:05 PM (#57490 - in reply to #57462)
Central New York
Pin G and H. I do not recall which connector half I did, it was the smaller of the 2 halves. Unclip the plastic wire retainer on the rear of the connector then push out the pin with a stiff wire. I used a torch tip cleaner because it was handy. I suppose a paperclip would work. Just poke around a bit till the tab releases and it will slid right out.
Digby
Posted 2010-04-14 4:49 PM (#57496 - in reply to #57462)
I just did the mod last week I used a small drill . Use the solid end and push with the flutes in a vise grip or leather gloves. don't forget to wrap with self stick electric tape.
Rakk17
Posted 2010-04-15 1:09 AM (#57549 - in reply to #57462)
Yahoo I got the pins out and forgot to get the tape today. lol have to finish it in the morning. Thanks for the help guys!
Victorywldr
Posted 2010-04-20 1:45 AM (#57980 - in reply to #57462)
Works great took 5 minutes.
firehawk
Posted 2010-04-20 11:39 AM (#57991 - in reply to #57462)
College Station, Tx
Did mine last night too... works great! Thank guys
whinchey
Posted 2010-04-20 1:41 PM (#58003 - in reply to #57462)
Yellowknife, NT Canada
If you pull the pins going to the back side of the bike, and tape them to protect them, the the leads that are powered for this purpose stay in the connector.. Just a thought...
