IPOD Lockup / pause
JSP
Posted 2014-06-24 9:02 PM (#160658)
Subject: IPOD Lockup / pause
on the edge of Los Angeles
So my 08 has got a new deal where I am playing music from ipod via the apple connector and it Pauses.  The display still shows the song but thats it.  I power cycle the radio and it comes back for a while and does it again.
I have unplugged the ipod and reconnected it thinking thats all that is wrong but it continues.
Anyone else seen this issue and if so what did you do.
Oh yeah its been working for over 100k
Thanks
TMOE4U
Posted 2014-06-24 9:24 PM (#160659 - in reply to #160658)
Subject: Re: IPOD Lockup / pause
Edmonton, AB Canada
I have a first generation iPod Touch that I use in my car all of the time. It does the same thing once in a while. I usually just unplug it from the cable and then plug it back in and it seems to come back. Once in a while I need to sync it with my computer to get it back going, but usually just unplugging it works.
I have not had any issues with the one in my bike.
BillyJoe
Posted 2014-06-25 5:16 AM (#160666 - in reply to #160658)
, AR United States
My connector does lock in anymore. I use rubber bands to hold it in place or it will come loose.
Posted 2014-06-25 5:48 AM (#160667 - in reply to #160658)
I replaced my cable once and found out it was the iPod. Went to the pawnshop and got a cheap nano and it continues to work great for about 2 years.
ljurgens
Posted 2014-06-25 7:34 AM (#160669 - in reply to #160658)
West Salem, WI United States
I have an older ipod touch and mine just started doing this yesterday too! I had just removed it (mine is in the XM pocket) the day before to sycn it with the PC for new music. Maybe its just not plugged in completely...
Posted 2014-06-25 8:19 AM (#160673 - in reply to #160658)
I had the touch the first go around, that is what had the problem. Try a nano and see how that works for you. The touch plug in didn't want to work in the Vision plug after a while. I discovered this when I replaced the cable and it still didn't work. It always worked fine on the PC though.
Posted 2014-06-25 5:51 PM (#160696 - in reply to #160658)
look on craigslist for great buys. Your will keep locking up on you think its cause it has a hard drive. You wanta 3rd gen or a 5th gen they work the best.
One of the guys here did a hole long write up about the ipod you might find it in the tech forum
Posted 2014-06-25 5:55 PM (#160697 - in reply to #160658)
at top of page is links click on it and scroll down to radiotech ipod its a pdf file and will tell you all you want to know
JSP
Posted 2014-06-30 8:47 PM (#160852 - in reply to #160658)
All good Information Thanks.
Murphy showed up at my door, and after fartn' around with it for a while and my testing I went ahead and ordered a new cable. Then it started working again.
tralphaz
Posted 2014-07-01 12:54 AM (#160857 - in reply to #160852)
Check the cable at the connector, sometimes they wear out, I replaced 2 Nano's back to back before realizing the connector had burned pins, it caused my Ipod to fail, got a new cable and used a little dielectric grease at the connection just for good measure.
RedRider
Posted 2014-07-01 5:33 PM (#160880 - in reply to #160658)
My stereo started acting crazy last fall. Shop/Vic determined it was the cable for the Ipod. The new cable was different than the old and had a jumper setup on it. It was replaced under the extended warranty. It acted up but different than before so I called Vic and the young lady was very nice to make an open work order at any dealer. It hasn't acted up yet so maybe she fixed it over the phone. Actually it plays songs that I never knew were on there. I only use it on the bike.
Something to look into.
