Help with part numbers
Prime Power
Posted 2011-07-27 4:59 AM (#91753)
Subject: Help with part numbers
Hello, I am in need of the plastic sight glass for the brake and clutch reservoir for my 2009 Vision Tour Premium. I cannot find the part numbers. Thank you
glighto11
Posted 2011-07-27 9:27 AM (#91771 - in reply to #91753)
Subject: Re: Help with part numbers
Central New York
I would be surprised if you found one. I don't believe it is a replaceable part. One would expect the only possibility would be an aftermarket part.
Posted 2011-07-27 11:21 AM (#91787 - in reply to #91753)
Subject: RE: Help with part numbers
Prime Power - 2011-07-27 4:59 AM
I am reluctant to ask but....What happened?
Prime Power
Posted 2011-07-27 11:35 AM (#91790 - in reply to #91753)
Nothing yet. I am getting them powdercoated and a little worried those little pieces might melt.
WillieByte
Posted 2011-07-27 11:44 AM (#91793 - in reply to #91753)
Plainfield Illinois
Just remove them first.  I had mine chromed and replaced them afterwards.
Prime Power
Posted 2011-07-27 11:46 AM (#91794 - in reply to #91753)
How did you remove them. I looked and couldn't get it. There at the powder coater but he hasn't started yet.
RedRider
Posted 2011-07-27 12:30 PM (#91799 - in reply to #91753)
If you do a search at TheVMC.com you will find all sorts of info about removing them and about powder coating them. A little research goes a long way.
Posted 2011-07-27 12:41 PM (#91802 - in reply to #91753)
I looked but did not see part number. You will have to ask your deal what comes in each kit or brake down of each kit. If still no good you could try silicon or jb weld. Here is a like to vic parts.
http://partsfinder.onlinemicrofiche.com/hondaeasttoledo/victory_oem...
Prime Power
Posted 2011-07-27 2:27 PM (#91814 - in reply to #91799)
RedRider - 2011-07-27 1:30 PM
Couldn't find it on there. I am on R&R, I am stationed in Kuwait so I don't have a lot of time to search and needed to get them to the coaters in a hurry. I want to spend a lot of time with my family while I can. If you have a link or know how to remove them I would appreciate it. Thanks
Posted 2011-07-27 6:31 PM (#91843 - in reply to #91753)
You will have to plug all holes and passages if the power gets in it will be junk and you know they bake the parts at 250 degrees for a hour or more.
When it comes down to it get it painted you don't really need power coating on the master cylinder.
Lotzafun
Posted 2011-07-27 9:54 PM (#91873 - in reply to #91753)
Rockford, IL
I'm gonna second the painting route. No need for powder coating them.
Prime Power
Posted 2011-07-28 5:01 AM (#91889 - in reply to #91753)
They are already at the coaters, so any help on how to remove the sight glasses would be appreciated. Plus, I have a good powder coater and he is cheaper than painting.
