New carbon
copatlarge
Posted 2012-06-12 5:15 AM (#116350)
Subject: New carbon
, MO
I seen another vision with carbon fiber wrap and had to do it.. Thinking about wrapping the side silver/grey panels and grab handles also but not sure.. may be too much..
bugmasai
Posted 2012-06-12 7:21 AM (#116358 - in reply to #116350)
Subject: Re: New carbon
DeRidder, LA
The side panels are tough, and take a lot more wrap than you think they should. That being said, with patience it can be done by an rookie like myself and looks amazing. I love mine.
copatlarge
Posted 2012-06-12 6:02 PM (#116427 - in reply to #116350)
, MO
You did your side panels in carbon? Got any pics?
LA Victory Rider
Posted 2012-06-12 6:45 PM (#116437 - in reply to #116427)
Monrovia, Ca
I recently did my dash, the inner fairings and the side covers. I will try and take some pictures tonight and post them.
Posted 2012-06-12 6:58 PM (#116441 - in reply to #116350)
I did the top V and all the side panels
I bought my CF from http://www.carbonfiberfilm.com/ your going to need the 48x48 for the top and one more for the side. Very fast shippers.
Its not bad to do but one trick I found out is have one or two heat lamps. The heat lamps will make the CF easer to form around corners and odd shapes easer. No heat lamps then get a buddy to help even if you have heat lamps ( rent them) heat gun works too. A new credit card worked best for me one with real clean edges not all chewed up.
I did the dash and the clutch cover and both wedges. As you fold the edges over make a slit in the CF about every two inches. Wash all parts with rubbing alcohol
This was the second season on them and they looked great. I didn't know why but I cleared them and like them as much.
I'm not a big fan of how the lighted badges stick out so I left the back off the and glued just the badges back on looks way better.
(IMG_0401.JPG)
Attachments IMG_0401.JPG (94KB - 4 downloads)
LA Victory Rider
Posted 2012-06-12 7:20 PM (#116446 - in reply to #116350)
Subject: RE: New carbon
Monrovia, Ca
Here are the pictures on a black bike
LA Victory Rider
Posted 2012-06-12 7:40 PM (#116452 - in reply to #116350)
Monrovia, Ca
truing to upload my pictures
goat813
Posted 2012-06-12 9:40 PM (#116461 - in reply to #116350)
W'ford Tx
Quick search on eBay and found they make chrome vinyl wrap.....
Edited by goat813 2012-06-12 9:42 PM
bugmasai
Posted 2012-06-13 3:21 PM (#116502 - in reply to #116427)
DeRidder, LA
I'll try to attach some pics.
Didn't work, will have to get pics on the comp and make them smaller when I get the chance.
Edited by bugmasai 2012-06-13 3:24 PM
PhantomX
Posted 2012-06-14 2:36 PM (#116606 - in reply to #116350)
Land O Lakes, FL
Where do you get the wrap? How hard is it to do? I would love to do some of the items on my Vision!
Posted 2012-06-14 6:14 PM (#116623 - in reply to #116350)
Heres where I bought mine http://www.carbonfiberfilm.com/ they have nine colors to chose from
48x48 is what you need for the top V or big side covers. For me a new credit card with smooth edges worked great. Wash parts with rubbing alcohol.
A Buddy will be a big help. Heat lamps will really help I found heat makes the CF very easy to work with and you can rent them. Don't get them to close cause you can melt a hole in the CF. If you don't go that way you need a heat gun to shape the CF around edges and curves. I learned the hard way heat really helps and another hand or two helps.
When you roll it over the edges cut the CF every two inches. Its not hard to do it just scary. Do little peaces first to kinda get the hang of it. Once you press it down its all most permanent if want to take it off and reshape it.
(badge.JPG)
Attachments badge.JPG (49KB - 1 downloads)
DannyB
Posted 2012-06-15 5:37 AM (#116675 - in reply to #116350)
2 mi from Jim Beam n KY
Totally BA!!!!!!!!!!!!!!!!!!!!! I'm adding that on list of things to do!!!
bbrist
Posted 2012-06-15 5:56 AM (#116677 - in reply to #116350)
If your really into carbonj fiber this web sight will sell you the real deal for covering your ride in cf.
http://store.carbonfibergear.com/carbon-fiber-starter-kit/
