best place to tie in a voltmeter ?
azllerbob
Posted 2010-11-13 8:09 PM (#73422)
Subject: best place to tie in a voltmeter ?
Parkersburg WV
Hi all, next to my vision now sits a vegas Im going to install a led voltmeter and wonder wheres the best place to tie it in ?
Thanks in advance for you input !!!
Bob
Flatsix
Posted 2010-11-13 9:45 PM (#73427 - in reply to #73422)
Subject: RE: best place to tie in a voltmeter ?
Fargo, ND
I would go direct to the battery...Good luck with your project!
Posted 2010-11-14 12:01 AM (#73431 - in reply to #73427)
Flatsix - 2010-11-13 9:45 PM
+1...Get it from the source!
azllerbob
Posted 2010-11-14 8:12 AM (#73446 - in reply to #73427)
Parkersburg WV
Hi, this needs to be a place where the juice is only on when the key is on...not constant.
Thanks, Bob
azllerbob
Posted 2010-11-14 8:15 AM (#73447 - in reply to #73446)
Parkersburg WV
I was thinking about the fuel pump wires under the tank or opening up the headlight bucket and going with the low beam. On the Honda's Ive owned there was an accessory pllug I tied into but Im not familiar with the wireing harness of the Vegas.
Bob
Posted 2010-11-14 8:22 AM (#73448 - in reply to #73422)
Subject: Re: best place to tie in a voltmeter ?
Bob,
You are so right. Sorry.
Ride Safe
azllerbob
Posted 2010-11-14 4:18 PM (#73464 - in reply to #73422)
Parkersburg WV
I went into the headlight bucket and tied into the low beam headlight this afternoon.
Bob
sgiacci
Posted 2010-11-15 7:52 AM (#73505 - in reply to #73422)
You want to avoid any load in the loop and tap directly into ignition switch. I think it is either the pink or brown wire that is switched.
Posted 2010-11-15 11:07 AM (#73527 - in reply to #73422)
Great information! Learned something new today...Radioteacher can be wrong...sometimes..
sgiacci
Posted 2010-11-15 12:18 PM (#73536 - in reply to #73527)
varyder - 2010-11-15 11:07 AM
Not really, if it is a 3 wire meter it would be connected directly to the battery with a relay that turns it one with the ignition.
Posted 2010-11-15 12:36 PM (#73539 - in reply to #73422)
Thanks Steven, I stand correct, I should have said that RT can admit when he's wrong...
If I ever get a Vegas Low this is a great mod
Posted 2010-11-17 12:45 AM (#73657 - in reply to #73422)
I am wrong quite often.....just ask my wife.
Ride Safe
KansasGuardsman
Posted 2010-11-18 10:15 PM (#73864 - in reply to #73422)
Wichita, Kansas
The easiest place is the grey plug under the console rear plate in front of the seat for the accessory plug. It takes spade terminals and is off with the key. No cutting or splicing and easy to get to.
