mechanic says the Viision Needs new braoke pads
kodonnell1
Posted 2012-03-15 7:59 PM (#110201)
Subject: mechanic says the Viision Needs new braoke pads
Hello All , i have a 2009 Vision and thios year i needed a saftey done to register it. The mechanic says the rear brake pads are shot. I have 20,000 miles on the bike. I was wondering if they are scamming me for a 300 dollor job. Has anyone else have to replace the rear pads after only 20,000 miles? What is the average lifespan of the rear pads. Thank you all for your help.
Posted 2012-03-15 8:11 PM (#110202 - in reply to #110201)
Subject: Re: mechanic says the Viision Needs new braoke pads
20,000 is not unreasonable, depends on your braking habits. Also, check the rotor and calibers for any unusual play.
cchristo
Posted 2012-03-15 8:20 PM (#110203 - in reply to #110201)
san antonio, tx
It's a very simple do it yourself job, if you want to do it yourself. 20K is not unreasonable, depending on your riding habits. I don't get that much out of mine.
Anyway, just have him show you the pads if you have them do it. If they have it on a lift, you'll be able to tell without even removing them.
SammyJ
Posted 2012-03-15 8:25 PM (#110204 - in reply to #110201)
Princeton, IL
I just changed mine at 47,000 and they were not in bad shape. I agree with the others though, it all depends on how you ride. I changed them in about 15 minutes, including cleaning all the parts. You can probably do it yourself. Just my two cents.
Posted 2012-03-15 9:07 PM (#110214 - in reply to #110201)
My 08 vision needed new brakes at 21000 miles.
Eric
Posted 2012-03-15 9:18 PM (#110216 - in reply to #110201)
Duanesburg N.Y.
the caliper hangs low enough, crawl under and check them out
savage
Posted 2012-03-15 9:24 PM (#110218 - in reply to #110201)
20K miles on a set of pads is reasonable......$300 for a 15 minute job......not so much!
Posted 2012-03-15 9:58 PM (#110219 - in reply to #110201)
I made the mistake of believing my service department (kind a) when they told me my brakepads needed replacing during the 15k service, so I went home after the service and ordered some off ebay (about $50 for all 3 sets). When I replaced the front tire at 17k, I popped in the new pads as well, only to find I had a good 5-10k left on them. It's just so easy to do though when the wheel is off.
If they say they need replacing at 20k, they may just be a tad overcautious like mine.
If they are charging you $300, then they are trying to scam you.
SYNSTR
Posted 2012-03-15 10:49 PM (#110223 - in reply to #110201)
Mt. Vernon, WASH.
If you do crawl under to have a peek, take a 1" micrometer along and measure the tapering wear on the rotor from as close as you can get to the axle to the edge. No point in putting new pads on a pizza cutter cuz you'll just be back down there replacing the rotor and compromising your and others safety with half fast brakes.
kris1956
Posted 2012-03-16 5:04 AM (#110230 - in reply to #110201)
300.00 to replace rear pads? As someone else said, it takes at best 15 minutes. Is this a Victory dealer telling you this?
Posted 2012-03-16 8:02 AM (#110237 - in reply to #110201)
Sorry, did not respond to the cost factor. I don't know the breakout of the cost and what the book calls for time to do the job. No matter what you think the time would be, the dealer goes by the book time to charge labor. Ask them to itemize the cost, then ask us if that is a fair price.
Kelvininin
Posted 2012-03-16 12:56 PM (#110256 - in reply to #110201)
Subject: RE: mechanic says the Viision Needs new braoke pads
I think I mustered 8K on the rears of my KP. The Vision is still hanging in there at 15K.
20K for new pads sounds alright. $300 sounds like too much.
Cometman
Posted 2012-03-16 2:52 PM (#110260 - in reply to #110201)
Simi Valley, CA
Did my brakes at 24k.... did them myself took 30 mins.... bought the pads on ebay.
kris1956
Posted 2012-03-17 5:36 AM (#110276 - in reply to #110201)
I called my dealer and he charges half an hour labor at 110.00 an hour.
viclvr
Posted 2012-03-17 1:18 PM (#110289 - in reply to #110201)
Princeton, MN
Did mine yesterday with Llyndale gold pads in 15 mins,,,, if you can take out one bolt you cann do it!
Posted 2012-03-17 4:46 PM (#110296 - in reply to #110201)
Put you bike on the right hand tip overs. With a wrench you pull the very front pin silver in color and maybe about a 5/15" bolt head. Slide the shoes out put the new ones in. Lift the bike wash your hands and now you have time to cut the grass.
aaronrkelly
Posted 2012-03-18 10:51 PM (#110396 - in reply to #110201)
Moravia, IA
I noticed my rear pads were REAL thin one day on a pre-ride check before going to work.
Laid the bike over, grabbed a ratcheT and socket and changed them in less than 15 mins.......my uniform stayed clean......and I wasnt even late for work.
$300 for that job - FUGGIN highway robbery.....
g1nomad
Posted 2012-03-19 2:07 PM (#110439 - in reply to #110201)
SC, Bluffton
Some of that dealerships quoted cost had to have included changing the brake fluid as well?
