I'm removing the Thrust mufflers
Biscuit
Posted 2011-03-20 7:22 PM (#81802)
Subject: I'm removing the Thrust mufflers
Midlothian, Va.
Just can't get rid of the popping and it's driving me crazy. The exhaust is tight and I'm running a stock air filter. Any cheap suggestions are welcome, thanks.
roundtwig
Posted 2011-03-20 7:45 PM (#81806 - in reply to #81802)
Subject: Re: I'm removing the Thrust mufflers
flagstaff, AZ
I am running an 09 stock with the thrush without tips yet, running only the 87 octane fuel and i get the occasional slight pop (same as with stock mufflers). Sorry not much help
Miles
Posted 2011-03-20 8:08 PM (#81809 - in reply to #81802)
I'm not familiar with Thrust mufflers... but the comment "The exhaust is tight and I'm running a stock air filter." caught my eye. If you change the exhaust, then unless it's exactly the same flow as stock, something else needs to change too... usually the intake side, but there are too many variables to troubleshoot online. I'd give Lloydz (lloydz.com) a call.
Cap'n Nemo
Posted 2011-03-20 9:54 PM (#81814 - in reply to #81809)
New Bohemia, Va
Miles - 2011-03-20 8:08 PM
yep!
marcparnes
Posted 2011-03-20 10:10 PM (#81816 - in reply to #81802)
Subject: RE: I'm removing the Thrust mufflers
Interestingly, neither my 2011 VV or my friend's CC pop at all. I had a 2010 before with the pop that I couldn't get rid of. I asked Lloyd what he thought they might have done to get rid of it and all he could comment on is that they have increased the map resolution significantly which allows them to tune it finer. One thing that I have noticed is that when the bike is fully up to temperature and you're slowing down in 2nd gear at about 2000 rpm as an example and then start to open the throttle again, like when you're going around a corner, the motor will hesitate and then lurch forward. It only does this when its good and hot. If the bike sits for 20 minutes or so and you ride off it won't act up again till the temp comes up. The 2010 didn't have this glitch so its almost like they tuned the pop out and tuned a hesitation in. You just can't win. I played around with the PCV but it has no effect on this problem at all. I think its related to the fuel cutoff switch built into the OE software. Now I'm just trying to figure out a way to "ride" around the problem.
Marc
buddahead
Posted 2011-03-20 10:14 PM (#81817 - in reply to #81802)
SF Bay Area
Many stock Visions have an occasional exhaust pop on decell, especially when cold. When stock, this exhaust popping is hard to hear, but when running an open pipe it becomes very apparent. Many think the popping is caused by the open pipe because of this.
Having said this, I have had other bikes (non-Vics) exhaust pop due to an exhaust clamp or gasket leak.
BillyJoe
Posted 2011-03-20 10:29 PM (#81819 - in reply to #81802)
, AR United States
What about this? http://www.lloydz.com/store/item_view.asp?estore_itemid=1000078
Mine pops too, but I have a small leak at the crossover I have yet to seal up. Anyway it popped before I put on the Thrushes, just not as loudly.
Posted 2011-03-21 1:26 PM (#81856 - in reply to #81802)
I have read that KevinX has told people to disconnect your 02 sensors that will richen up your bike and take some if not all your popping away.
I think victory has a shity ecm and the bike run lean when you alter your exhaust. I think they changed the ecm in 2011
Biscuit
Posted 2011-03-21 1:49 PM (#81860 - in reply to #81802)
Midlothian, Va.
First thing I need to do is learn how to spell Thrush! My exhaust being tight means there are no leaks and I did this mod based on others saying there was very little to no popping. Well I have more than very little so I think I'm going back to stock to save what little hearing I have left. I must say the Thrush sound is as good as any I've heard on any kind of bike. Thanks for the reply's everyone.
Lojak
Posted 2011-03-21 3:26 PM (#81872 - in reply to #81802)
New Brunswick , Canada
How do you find an exhaust leak ? on hard excel. it will pop all the time , S1L1 Mod...
Posted 2011-03-21 4:43 PM (#81876 - in reply to #81802)
The Thrush is a 2" straight through opening. Any pipes you try equal to or more than that will pop the same unless you remap. S1L1 are 1-1/2" straight thru, may or may not still pop without a remap. Cycledragon says their's will work without a remap, and sound very good, but I cannot comment on whether it pops or not. The Lloydz IAV may fix the popping without a remap. Best to ask him directly.
LLOYDZ wrote a wonderful article on backfiring wich is a MUST READ for anyone changing from stock.
http://www.vision-riders.com/articles.asp?Article=59691&fid=40
marcparnes
Posted 2011-03-21 4:56 PM (#81877 - in reply to #81802)
I had the Cycle Dragon pipes on my 2010 with a PCV and Autotune and it popped consistently.
Edited by marcparnes 2011-03-21 4:57 PM
wtwhitelaw
Posted 2011-03-21 5:30 PM (#81879 - in reply to #81802)
Flowery Branch Ga
Popping will scare aware the deer. Which is worse?
Wayne
Posted 2011-03-21 5:33 PM (#81880 - in reply to #81877)
marcparnes - 2011-03-21 2:56 PM
What setup do you have now?
I have Thrush mufflers and the upgraded intake filter. I still get mild popping, only when I shift agressively. My bike may have had a remap prior to buying it. The dealer put S1L1s on it before the sale. I thought about putting in an adjustable lollipop baffle, but in never pops enough to make it worth the work.
marcparnes
Posted 2011-03-21 5:39 PM (#81881 - in reply to #81880)
Nozzledog - 2011-03-21 2:33 PM
I have a 2011 with the same setup as the 2010 but no popping.
Biscuit
Posted 2011-03-21 7:34 PM (#81893 - in reply to #81880)
Midlothian, Va.
Nozzledog - 2011-03-21 6:33 PM marcparnes - 2011-03-21 2:56 PM I had the Cycle Dragon pipes on my 2010 with a PCV and Autotune and it popped consistently. What setup do you have now? I have Thrush mufflers and the upgraded intake filter. I still get mild popping, only when I shift agressively. My bike may have had a remap prior to buying it. The dealer put S1L1s on it before the sale. I thought about putting in an adjustable lollipop baffle, but in never pops enough to make it worth the work. Stock filter and I put the lollipop baffle in also.
Biscuit
Posted 2011-03-29 8:12 AM (#82654 - in reply to #81809)
Midlothian, Va.
Made the exchange back to stock Sunday so now I'm quiet again. I'm going to miss that special sound but now I can hear the tunes a lot better and my almost lost of hearing is thanking me. Downside is all the bike noise is back. Update on a lost upper wind deflector that flew off a couple of weeks ago is the mother ship is sending me a new one under warranty. Any special instructions on the install as the closest dealer is 100 miles away.
Posted 2011-03-29 8:44 AM (#82657 - in reply to #81802)
i know this doesnt really help anyone, but my 08 popped stock and popped even more when i went to the s1l1 i even installed the IAV and not much luck. what DID help me was when i installed a fuel controller. i installed a pcv and my popping is almost gone and has been for 1 year.
XRsteve
Posted 2011-03-29 10:41 AM (#82670 - in reply to #82657)
Georgia, west of Atlanta
The Lloydz air valve has done good for me.................
RedRider
Posted 2011-03-29 11:07 AM (#82675 - in reply to #81802)
My "stock" 10th Anny has never popped nor did my '03 CC with straight pipes, K&N filter with front vented custom air intake cover and only the S1 download. I get very little on my '99 and she has straight pipes, K&N filter with no airbox, Lloyd installed and setup Techlusion and idle is set at 750. I always burn high test gas and use Amsoil. No idea what makes the difference but...
This won't help but it throws a lot of variables in there.
