Burping the gas tank
david.halen
Posted 2011-05-29 11:47 PM (#87447)
Subject: Burping the gas tank
El Paso, TX
Ok, it takes me sometimes over 5 minutes to simply fill up my tank with only 4 or 5 gallons. The problem is how to get the air flow. I fill up with it on the side stand and end up rocking it back and forth trying to burp it.
Anyone have any suggestions how to make fueling the Vision easier?
Posted 2011-05-30 4:16 AM (#87450 - in reply to #87447)
Subject: Re: Burping the gas tank
Fuel it slower.so the fuel has a chance to go to the other tank first.
handyhiker
Posted 2011-05-30 6:05 AM (#87452 - in reply to #87447)
Akron, Ohio
I have never looked at the diagram for the tanks, but it sounds to me like you have a problem. My fuel equalizes within seconds of filling the tank. I too fill off the side stand as Victory recommends. I also do as the above post says and fill slow enough so the fuel doesn't splash. It takes me no longer to fuel to the top than my brother on his Harley.
Big Vic
Posted 2011-05-30 6:12 AM (#87453 - in reply to #87447)
Southeast Iowa
I agree with the previous suggestions, Inever have to "burp" my bike. Try fueling slower to fuel faster.
mkultra
Posted 2011-05-30 6:25 AM (#87455 - in reply to #87447)
Tucson, AZ
I always burp it...takes more time than any other bike, but I'm never in that much of a hurry. It will fill to the top, but if i rock it I can alway get more in.......And with the new pump handles, you can't always fill real slow. I just put my foot on the right floorboard and give it a push....I'm on and 08 with 67,000 miles, so its habit now.
mike
Cap'n Nemo
Posted 2011-05-30 7:22 AM (#87461 - in reply to #87447)
New Bohemia, Va
slow steady fill. I'm a one hander, and use my left to pull on the left handle bar and rest my left foot on the right running board. When I get to the top I just do a steady gently rock, pushing down the right side some to allow it to equalize. Also, get on the side of the pump that allows your bike sit more up, if there is a slop.
XRsteve
Posted 2011-05-30 7:28 AM (#87462 - in reply to #87447)
Georgia, west of Atlanta
And I thought I was the only one doing the gas station dance..............
Webhair
Posted 2011-05-30 7:36 AM (#87465 - in reply to #87447)
Peachtree City, GA
An do the honky pokey and turn yourself around...
wibiker
Posted 2011-05-30 8:58 AM (#87472 - in reply to #87447)
not far from hustler wisconsin
i noticed similar fill too. I fill slowly, let it drop in level fill a bit more, let it drop then one more time and ......full tank.
SYNSTR
Posted 2011-05-30 9:53 AM (#87476 - in reply to #87447)
Mt. Vernon, WASH.
So, I'm not the only one who thinks the 'cartoonists' in engineering blew it by not designing in a cross over vent line eh??????
Posted 2011-05-30 12:12 PM (#87485 - in reply to #87447)
Were lucky think of that Crossbow trike. Must shake the hell out of it and never get full. But then they don't fall over.
david.halen
Posted 2011-05-30 1:08 PM (#87492 - in reply to #87447)
Subject: RE: Burping the gas tank
El Paso, TX
I'm glad to hear that I'm not the only one doing the floor board dance. Thanks for the feedback all.
Happy riding and keep the rubber side down!
Big Vic
Posted 2011-05-30 2:02 PM (#87495 - in reply to #87447)
Southeast Iowa
I believe there is a cross over vent but it will not allow air to escape as fast as you can put the gas in. That's why some fill a little slower and some do the "burp"
Posted 2011-05-30 3:00 PM (#87500 - in reply to #87447)
When you pill the right tank fuel goes threw the bottom hose and its pretty good size. That forces air out a small vent on top. I would have minded piling both side instead of one side.
MaddMAx2u
Posted 2011-05-30 8:48 PM (#87540 - in reply to #87447)
Orlando, FL
I'm a burp'er. I always seem to get more fuel in that way. It takes another 30 seconds, and I am never in a rush.
norcan
Posted 2011-05-30 9:50 PM (#87545 - in reply to #87447)
Edmonton Alberta, Canada
I fill slower, never worry about getting in that last litre......my Harley buddies always looking for a station before I am at a 1/4. I have never been where that last 1-2 litres away from a station. Just me I guess.
RhodeTrip
Posted 2011-05-31 4:13 AM (#87553 - in reply to #87447)
Rhode Island
Pump slow is the ticket, but it isn't a problem once you learn to maintain a light steady pressure on the pump handle while you talk; I can't stop for gas without answering lots of questions so 5 minutes goes quick.
Jim
rainryder
Posted 2011-05-31 3:02 PM (#87604 - in reply to #87447)
Bay of Gigs, WA
If the li'l gal filling her Honda Civic at the next island over has her short shorts on it can take me a gawd-awful long time to burp my tank. Just sayin'..
MaddMAx2u
Posted 2011-05-31 5:20 PM (#87615 - in reply to #87447)
Orlando, FL
I hear that Rainryder. I always seem to have the same problem. Of course the bigger problem is when my passenger starts asking me what's taking so long!!! LOL
Boots
Posted 2011-05-31 6:55 PM (#87632 - in reply to #87447)
New Mexico
My last bike I was able to put a small hole towards the top of the filler neck, which increased fill time considerably. Looking at the Vision filler neck it doesn't appear that is possible, but if it was would sure solve the problem.
hoosiervic
Posted 2011-05-31 9:40 PM (#87648 - in reply to #87447)
Indianapolis, IN
Just a suggestion guys. It stands to reason that if either the upper crossover tube or the lower crossover tube are pinched, kinked or blocked in any way, this would cause the filling of the left side to be much slower.
I don't fill fast enough to cause the fuel to splash out but I don't spend any more than two minutes on an empty tank and I never have to burp. When my low fuel message comes on I usually need about 5.2 gal to the filler neck, without burping and still within two minutes. I would give those crossovers a look-see just to make sure.
bigfoot
Posted 2011-06-01 8:56 AM (#87668 - in reply to #87447)
Akron Ohio area
I now have over 7,000 miles on my 2011 Vision Tour and haven't had any problems filling the tank.
I've put as much as 5.7 gallons in it and all I do is raise the nozzle to just below the top of the filler neck and pump the last gallon or so slowly.
I have tried to shake the bike side to side to see if I can get more fuel in it, but the level does not go down.
As mentioned above, check the cross-overs.
