How to get Bug Juice off the Alum Panels?
candubrain
Posted 2009-05-30 7:45 PM (#35674)
Subject: How to get Bug Juice off the Alum Panels?
Kincardine, Ontario, Canada
Okay, I'm not know for washing my bike regularly. But when I do, I want it clean when I'm done.
I'm finding that old bug juice is hard to remove from the aluminum panels. I've tried bug remover, but the surface is more porous than a painted smooth area, so it likes to hang on to that dirty bug.
Ideas?
Digby
Posted 2009-05-30 8:14 PM (#35675 - in reply to #35674)
Subject: Re: How to get Bug Juice off the Alum Panels?
"Simple Green". Spray on wait 5 minutes hose off. the majority of the goo will fall off! What doesn't go on the first rince easily comes off with the spong.
candubrain
Posted 2009-05-30 8:59 PM (#35676 - in reply to #35674)
I'm going to try that, thanks
Digby
Posted 2009-05-30 9:36 PM (#35682 - in reply to #35674)
Tis the season in our neck of the woods. I believe Ive got bugs an inch thick to get rid of tomorrow. Thanks to the adirondacks Ny ,vermont , New Hampshire and of course Maine.
Posted 2009-05-30 11:03 PM (#35684 - in reply to #35674)
i use the S-100 stuff. spray it on there wait 3-5 mins and hose away... then i use a bucket of soapy water to wash her down real good. Then and this is the part i like.. i use that MR CLean auto dry to do the final rinse.. I love that thing! I just let it dry either in the sun or how ever and it is almost completely spot free afterwards.
Blue Demon
Posted 2009-05-30 11:30 PM (#35685 - in reply to #35674)
Kansas City, Ks
I use Honda Cleaner or Thunderbolt Polish..
Oddly enough just the other day I was cleaning the bike and was actually debating the painting that I wanted
to do to the aluminum panels due to them be so easy to clean!!
bruzer
Posted 2009-05-31 3:48 PM (#35712 - in reply to #35674)
Aberdeen SD
What really works good is get a pack of citris wipes they come in a sealable package you carry with you they just wipe right off even if they ahve been on for awhile also works on the windsheild can be gotten at about any place walmarts $ stores
Blackjack
Posted 2009-05-31 4:39 PM (#35713 - in reply to #35674)
Cottage Grove, Mn
chrome'em
Digby
Posted 2009-05-31 4:43 PM (#35714 - in reply to #35674)
I like that too!
Vinner1
Posted 2009-05-31 7:06 PM (#35720 - in reply to #35674)
Hartland, , WI
I use Bug Slide...it works great...it builds up a nice surface over time too so they keep coming off easier.
buddahead
Posted 2009-05-31 7:47 PM (#35721 - in reply to #35674)
SF Bay Area
Simple Green and S100 are acids... if you have any flaw or defect in the clear coat on your aluminum panels these chemicals will turn your panels dark gray due to the chemical etching. Don't get me wrong... I use S100, but not on my aluminum parts, unless they are painted... I do not the stuff near my engine fins. If you do get the stuff on a bare aluminum part, you will need to rinse the stuff off completely, or it will corrode and etch the metal.
I use either ProtectAll or Honda spray polish, spray liberally/soak it well, and remove the liquified bugs with an old diaper. Kinda gross, (the bugs, not the diaper!) but it works. If you coat your cleaned aluminum panels with something like Mother's carnauba wax, it make future bug cleaning easier, often only needing a wet rag.
Finally, here's a thought... I have successfully used a coin op spray car wash gun to clean dried bug guts, seems to work well, without any chance of scratching the surface finish.
candubrain
Posted 2009-05-31 7:50 PM (#35722 - in reply to #35674)
I remember last year coming back from Montana, this gas station had some bug cleaner in the squeegee pail. Something like Dinosaur bug remover or Dino Clean, I can't remember what it was called, but it was pink and it cleaned the front of the bikes real good.
Teach
Posted 2009-05-31 8:34 PM (#35725 - in reply to #35674)
I use the Honda spray cleaner for just quick cleanup of the entire bike (takes the bugs and guts right off) and I use Simply Green for washing the bike type cleanup. Simple Green is completely bio safe and will not harm any part of your bike, painted surfaces or otherwise.
exharleyrider
Posted 2009-05-31 8:50 PM (#35727 - in reply to #35674)
i am not known for cleaning either. if it is nice enough to clean it is nice enough to ride. i simply take a used terry towel, wet it well, and spread it flat onthe windshield and the rest of the front of the bike. come back out in the morning and wipe off the bugs. really sticky bugs might take a secong application of towell. never found anything easier than this.
clubford00
Posted 2009-06-01 12:18 AM (#35731 - in reply to #35674)
Buffalo Grove,Ill
I use extra strength 409 on the whole bike works great on everything including the bug guts !
Member No. 1
Posted 2009-06-01 4:14 AM (#35733 - in reply to #35731)
Under the Rule of Jedi - Masshole
Before this turns into an "Oil" thread, just a little clarification. Not to say your wrong Mike, I know you better than that, and value your info.
But for anyone unsure if this will hurt the aluminum, try it somewhere it won't show incase it does discolor.
Simple Green is a base not an acid. It has a pH of 9.5 +/- .3. A pH of 7.0 is neutral anything below is an acid anything above is a base.
Also have a look at Simple Green MSDS here:
http://www.simplegreen.com/pdfs/09A_msds_simple_green_pad.pdf
Couldn't find a MSDS for the S100
Oh and in case you don't know, MSDS stands for Material Safety Data Sheet. Pretty much if not all products have one.
Edited by Member No. 1 2009-06-01 4:17 AM
wjoel
Posted 2009-06-01 5:57 AM (#35736 - in reply to #35674)
Subject: RE: How to get Bug Juice off the Alum Panels?
Northeastern Penna.
I don't know what bug n tar remover you tried first, but Turtle wax spray bug n tar remover
works great. RainX has a new product- bug n tar remover gel.
ElroyJ
Posted 2009-06-01 5:20 PM (#35782 - in reply to #35733)
Centennial, CO
Heh heh...this is WHY I LOVE this forum. If you are every wondering about the details...YOU guys/gals have the answers...to the nth degree. I LOVE IT! Keep it up!
candubrain
Posted 2009-06-01 7:03 PM (#35797 - in reply to #35674)
I have unsuccessfully use the Harley Davidson Tar and Bug remover, but it's too weak. Okay for the windshield, but really doesn't touch the stuff on the Aluminum
Nepper
Posted 2009-06-01 7:54 PM (#35803 - in reply to #35674)
Buy yourself a box of no-name brand dryer sheets. The stuff they impregnate the sheets with not only softens clothes but disolves organic matter like bugs. Just dampen the dryer sheet and wipe it over the surface, the bug guts will begin to disolve and the water turns a bit of a milky color, then just wipe it away with a fresh damp microfiber cloth. I know this sounds odd but it works and I know this because I live in Northern Ontario so believe me I have some experience to back up what I say. This insn't something I came up with, I picked it up off another bike forum before I had my Vision.
Member No. 1
Posted 2009-06-01 8:18 PM (#35806 - in reply to #35803)
Nepper - 2009-06-01 8:54 PM
I've heard that to.
From a google search:
http://www.thriftyfun.com/tf742433.tip.html
I had a big spot of road tar on my car. Here is the solution and it worked beautifully!!! Wet the spot, take a new dryer sheet and rub it on the spot. Came right off!!! Won't damage the paint and took little to no effort to get it off. Also works on those nasty old bug guts on the front grill!
Or here:
http://www.doityourself.com/stry/dryersheets
http://www.google.com/search?client=safari&rls=en-us&q=dryer+sheet+...
STARSHIP 1
Posted 2009-06-01 10:00 PM (#35819 - in reply to #35674)
Houston, Texas
My sister lives in Florida and every May and October the 'love bugs' are swarming; we have the same problem in Texas. My sister turned me on to the dryer sheets a couple of years ago and they work great on the 'love bugs.
As Nepper says; wet the dryer sheets and I work them in a circular motion and they just disappear.
3M should do some research on 'love bug' guts.....its the damnedest adhesive I've ever seen.
Victorywldr
Posted 2009-06-02 12:19 AM (#35827 - in reply to #35674)
Just use Windex It works the best. Just don't get it on the waxed panels.
The vetts
Posted 2009-06-03 9:32 PM (#36012 - in reply to #35674)
Go to your Victory dealer and get the pure Victory Polishes cleaning kit. It is a little spendy but if you wash your bike often it pays for itself.
When you get the bugs of the windshield and chrome front, Use the Pure Victory Windshield, Paint and Chrome Polish on the windshield and the chrome front. Then all I have to do is use the Bike wash concentrate and water to get the bugs off a lot lot easier. Im sold on it.
Candyman
Posted 2009-06-04 12:37 PM (#36047 - in reply to #35674)
West Knoxville TN
Simple cheap spray wax. I take the bottle of spray wax and clean off the bugs with a micro cloth every time I finish a ride. Works like a charm. 3 dollars a bottle and it shines at the same time.
