Clutch Master Cylinder service
ingle51
Posted 2012-03-01 11:30 AM (#108969)
Subject: Clutch Master Cylinder service
NE Florida Jacksonville
I got stuck in a blowing sand episode and when I got home had to clean out a lot of sand. I noticed that both the front brake and clutch levers were pretty coated with grit. Just a reminder to make sure you clean out the brass pivot barrel and the area around both master cylinders in servicing the levers.
(Clutch Lever and brass pivot (Small).JPG)
(Clutch Master Clynder (Small).JPG)
Attachments Clutch Lever and brass pivot (Small).JPG (81KB - 1 downloads)
Attachments Clutch Master Clynder (Small).JPG (59KB - 1 downloads)
Posted 2012-03-01 5:59 PM (#108991 - in reply to #108969)
Subject: Re: Clutch Master Cylinder service
I do mine one a year just so its easy pull. Never been in a dust storm
kevinx
Posted 2012-03-01 6:07 PM (#108992 - in reply to #108969)
Should be done evert 5K, and don't forget to do the arm on the bottom as well
