odyssey pc545 battery???
sonicbluerider
Posted 2012-10-06 7:39 PM (#124818)
Subject: odyssey pc545 battery???
, IA
does This battery fit a vegas and vision with out having to add spacers for any type of other support or adjustments
ByteN2it
Posted 2012-10-06 10:33 PM (#124824 - in reply to #124818)
Subject: Re: odyssey pc545 battery???
I've had the 545 MJ in a couple of my Victorys-same battery just has a metal jacket-they fit width & length but I had to put a 3/4" shim under them to get the height right for the terminal connections as they're shorter than stock. BatteryMart used to throw plastic shims if you asked for them when ordering. They're great batteries and I wouldn't let having to add a spacer be a deal breaker. Brian
Posted 2012-10-06 11:10 PM (#124828 - in reply to #124818)
Subject: RE: odyssey pc545 battery???
I have an Odyssey PC545 and like Brian said you need to shim the bottom to lift the battery up. Make sure you shim it enough so the battery is tight against the top battery box clamp.
I thought the factory battery could have fit tighter, could be why so many have had loose battery connections.
