Amsoil Victory Article
kevinx
Posted 2010-10-09 7:55 PM (#71333 - in reply to #71236)
Subject: Re: Amsoil Victory Article
varyder - 2010-10-07 11:00 PM
I'm curious now, do you have personal knowledge of how many times it has been torn down Kevin? That's a significant piece in making a claim, but it would be no surprise if that was zero.
I'm over 83,000 miles and the motor is strong, does not use oil, leak or smoke. I see well over 100,000 on mine without ever going into the motor, but that is yet to be seen.
It has been apart more then once
Posted 2010-10-09 8:28 PM (#71334 - in reply to #71200)
well, if you have personal knowledge, his article means nothing to me, he could have been using pure virgin olive oil just the same.
iluvink
Posted 2010-10-11 3:38 PM (#71438 - in reply to #71200)
Dallas, Texas
Has no one besides me, used Motul Twin-Syn??...it is a semi syn, and I use 20W50...works great
VaParadox
Posted 2010-10-11 11:23 PM (#71473 - in reply to #71200)
Richmond, Virginia
+1 Amsoil my 08 is quieter, smoother, cooler, and slips into Neutral much easier since i flushed and filled with Amsoil. Rotella is good but it doesnt bone up my ride it would be second place if Amsoil wasnt available
scottcher
Posted 2011-08-28 5:45 PM (#95019 - in reply to #71317)
I couldnt find 20w40 amsoil I dont think they even make it so I got the 20w50 I hope that is fine cause its already in my bike Ha!
Posted 2011-08-28 5:55 PM (#95021 - in reply to #95019)
scottcher - 2011-08-28 5:45 PM
you dont need 20w40, 10w40 would do just the same. as the w40 is whats important.. the number before the W is how it flows in cold temps... Im running 10w40 amsoil in my vision right now. my oil change interval is 5000 miles so i dont feel as bad about using a expensive oil compared to when my oil change interval was 2500 miles
iluvink
Posted 2011-08-29 1:05 PM (#95084 - in reply to #71200)
Dallas, Texas
Oh boy..oh boy...a zombie oil thread...I like the Motul, but am thinking of going with Brad Penn...still semi-syn, but has that special PA oil...Mobil1 Syn is a great full syn..
paulhu
Posted 2011-08-29 1:24 PM (#95086 - in reply to #95084)
Durango, Colorado
Just switched from the Vic oil to Rotella T6 @ 18,000 mi. on my 08'. Not sure if it's quieter, shifts better, runs harder, or corners better.......But.....I think the stereo is Louder!
     -paulhu
kris1956
Posted 2011-08-29 2:14 PM (#95090 - in reply to #95086)
paulhu - 2011-08-29 1:24 PM
???? -paulhu
Use Rotella T6 on my 08 as well. Shifts much better. And no clutch slippage.
iluvink
Posted 2011-09-02 8:44 AM (#95444 - in reply to #71200)
Dallas, Texas
Even with a rating of JASO MA, can an oil be too thin or slick for our Victory engine?
Posted 2011-09-02 11:32 AM (#95463 - in reply to #71200)
I think if you use motorcycle oil all is good. There is a shear factor between car oil and motorcycle. After reading some good oil articles they say the smaller the number before the W is the weight of the oil for start up. So 10 weight is thin and your piston slides threw it easier then 20 weight. But the difference is very small. 90% of rings and motor wear is at start up. Revving the motor is a NO NO cold or hot. When cold start ups and you rev your motor the piston skirts will score the cylinder walls. That means a loss of power over time.
Synthetic oil will keep your bike running cooler then conventional oil.
